Headlights |
Headlights |
stevend914 |
Dec 19 2018, 04:27 PM
Member Group: Members Posts: 376 Joined: 13-December 16 From: Saint Louis Member No.: 20,670 Region Association: Upper MidWest |
On my 1970, the headlights popup when turning on the parking lights. Is it possible to rewire the switch so that the headlights will only popup when I turn on the headlights? I'd like to be able to drive with the parking lights only on and not have the headlights popup. (IMG:style_emoticons/default/driving.gif)
ctc911ctc |
Dec 19 2018, 05:33 PM
Senior Member Group: Members Posts: 893 Joined: 9-June 18 From: boston Member No.: 22,206 Region Association: North East States |
On my 1970, the headlights popup when turning on the parking lights. Is it possible to rewire the switch so that the headlights will only popup when I turn on the headlights? I'd like to be able to drive with the parking lights only on and not have the headlights popup. (IMG:style_emoticons/default/driving.gif) Moving the Motor to the headlight "on" terminal would accomplish this, the fusing may not like both of these loads on the headlamp fuse. I would also check the gauge of the supply side. Last, the switch rating may also be pushed beyond it's limit. sizzle..... A kludge might be to put a disconnect toggle on the motor actuator circuit. Lamps down until you throw the toggle. If I get to it I will look at the flow-down schematic and provide pointers this weekend....though there is a rumor that I need to go shopping.........hhhmmm |
rudedude |
Dec 19 2018, 06:06 PM
Senior Member Group: Members Posts: 510 Joined: 1-January 05 From: minneapolis, mn Member No.: 3,387 Region Association: Upper MidWest |
very easy to do involves moving one wire on the headlight switch. If I wasn't so old I could tell you which one. Somewhere I have it written down if no one else comes up with it sooner I can find it for you.
toolguy |
Dec 19 2018, 06:24 PM
Senior Member Group: Members Posts: 1,270 Joined: 2-April 11 From: San Diego / El Cajon Member No.: 12,889 Region Association: Southern California |
on the headlight switch move a gray wire from term #K to Term # 56
stevend914 |
Dec 19 2018, 08:42 PM
on the headlight switch move a gray wire from term #K to Term # 56 OK, thanks for the reply (IMG:style_emoticons/default/piratenanner.gif) |
Lo-Fi Version | Time is now: 1st June 2024 - 08:50 PM |
