Flywheel Fun, Some questions about compatibility |
TonyAKAVW |
Jun 20 2005, 12:12 AM
That's my ride. Group: Members Posts: 2,151 Joined: 17-January 03 From: Redondo Beach, CA Member No.: 166 Region Association: None |
I am doing a Subaru conversion and got a very good deal on a KEP adapter plate and flywheel. Trouble is that the flywheel appears to be a 200 mm flywheel. It seems that I have a few options. I'm looking for some input on what to do...
My options (that I can think of): a) Use a 200 mm (VW) clutch and pressure plate (I don't even know if this is possible with a 901 transmission. Anyone know if this could work?) I would have to get a stiffer clutch to compensate for the smaller surface area I believe. b.) Have the flywheel machined to give me 215 mm of useable diameter. Also don't know if this is possible. c) Just get a new flywheel made for the 215mm clutch. d) Have the center of this new flywheel removed and get my stock 914 flywheel modified (not sure who would do this) e) ???????? -Tony |
TonyAKAVW |
Jun 20 2005, 09:48 AM
TonyAKAVW |
Jun 20 2005, 02:27 PM
Here's a picture of the new flywheel which measures just over 200mm across the large flat area.
Attached image(s) |
TonyAKAVW |
Jun 20 2005, 02:28 PM
And my stock 1.8 flywheel, which measures around 220 mm across the open flat area.
Attached image(s) |
Mueller |
Jun 20 2005, 03:02 PM
TonyAKAVW |
Jun 20 2005, 03:31 PM
That's what I read, but I just don't know if a pressure plate/clutch that size would work on a 901 transmission. I'm not really sure what would be different, perhaps where the transmission shaft goes into the clutch disk? Are the splines going to match? Is the diameter of the main shaft going to work out? Also the release bearing, I'm wondering how that will work. -Tony |
Joe Bob |
Jun 20 2005, 03:42 PM
Retired admin, banned a few times Group: Members Posts: 17,427 Joined: 24-December 02 From: Boulder CO Member No.: 5 Region Association: None |
It'll work fine. I'm using the 200mm in my 356 conversion. 140hp....215mm is better but requires the flywheel to be cut again...obviously...just make sure the right TO bearing is used....
TonyAKAVW |
Jun 20 2005, 03:44 PM
Excellent! I'm assuming "the right TO bearing" is probably not going to be the one normally used on a 901 with a 215mm clutch. Thanks for the input! Tony |
Mueller |
Jun 20 2005, 03:45 PM
i do know that a 228mm pressure plate* bolts onto a 215mm flywheel (stock 914 size) and I'm guessing it would work with yours also
*i have a stage II refurbished by KEP sitting on a shelf |
TonyAKAVW |
Jun 20 2005, 03:48 PM
Looking at the pictures, it seems that because the inner diameter of the toothed ring is considerably smaller, that the bolt holes for the clutch plate are drilled on a smaller diameter ring. I'll measure it later and see if its just an optical illusion or not. -Tony |
Lo-Fi Version | Time is now: 7th June 2024 - 06:44 AM |
