Front suspension height adjustment, Which way to lower?? |
DRPHIL914 |
Jan 2 2019, 07:29 AM
Dr. Phil Group: Members Posts: 5,767 Joined: 9-December 09 From: Bluffton, SC Member No.: 11,106 Region Association: South East States |
Haynes does not state which way to lower/raise, and yes I did a full search and several threads discussing this were contradicting in that one person says tighten to lower and the other says opposite , so I ask again , which way?? please answer if you have done this recently or enough to be certain of your answer.
Phil |
cwpeden |
Jan 2 2019, 08:31 AM
Great White North, huh? Group: Members Posts: 916 Joined: 20-August 06 From: Victoria BC Member No.: 6,693 Region Association: Canada |
loosen = lower
IronHillRestorations |
I. I. R. C. Group: Members Posts: 6,719 Joined: 18-March 03 From: West TN Member No.: 439 Region Association: None |
Back the adjusters out (loosen) to lower
rhodyguy |
Jan 2 2019, 08:45 AM
Chimp Sanctuary NW. Check it out. Group: Members Posts: 22,082 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch |
Turn in or out might be easier. Turn in to raise. The opposite corner on the rear will see the greatest change. Small increments. You will need to roll the car back and forth a bit to 'settle' the suspention.
jim_hoyland |
Jan 2 2019, 09:12 AM
Get that VIN ? Group: Members Posts: 9,306 Joined: 1-May 03 From: Sunset Beach, CA Member No.: 643 Region Association: Southern California |
Haynes does not state which way to lower/raise, and yes I did a full search and several threads discussing this were contradicting in that one person says tighten to lower and the other says opposite , so I ask again , which way?? please answer if you have done this recently or enough to be certain of your answer. Phil Good question: would you post details. How much turning equals an inch, say. And whether you have to re-index (IMG:style_emoticons/default/smile.gif) |
VaccaRabite |
Jan 3 2019, 01:13 PM
En Garde! Group: Admin Posts: 13,446 Joined: 15-December 03 From: Dallastown, PA Member No.: 1,435 Region Association: MidAtlantic Region |
Turn in or out might be easier. Turn in to raise. The opposite corner on the rear will see the greatest change. Small increments. You will need to roll the car back and forth a bit to 'settle' the suspention. Also, unhook your front sway bar on one end when you do this. And understand that the car will need to be re-aligned after you have lowered it. Also, depending on how low you go, you may need to add bump-stop to keep the car from bump-induced steering. Zach |
Mueller |
Jan 3 2019, 01:23 PM
If I'm not mistaken, you could run out of adjustment just using the screw, if that happens you need to remove the adjuster and re'clock it on the splines
Lo-Fi Version | Time is now: 23rd May 2024 - 03:02 AM |
