Dash Top Vinyl, Just one simple question |
bbrock |
Jan 4 2019, 09:03 AM
Getting ready to do the dash top with the 914Rubber kit. Pretty straightforward but my original material was too far gone to serve as a template and I have one question. I know the vinyl should run long over the step down in the dash metal to terminate underneath the dash pad when it is installed, but what about the foam? Should the foam also run under the dash pad a little or should it be trimmed even with the step?
dr914@autoatlanta.com |
Jan 4 2019, 09:30 AM
914 Guru Group: Members Posts: 7,894 Joined: 3-January 07 From: atlanta georgia Member No.: 7,418 Region Association: None |
no the foam to the edge
Getting ready to do the dash top with the 914Rubber kit. Pretty straightforward but my original material was too far gone to serve as a template and I have one question. I know the vinyl should run long over the step down in the dash metal to terminate underneath the dash pad when it is installed, but what about the foam? Should the foam also run under the dash pad a little or should it be trimmed even with the step? |
bbrock |
Jan 4 2019, 11:58 AM
Simple question and simple answer. Thanks George (IMG:style_emoticons/default/beerchug.gif)
no the foam to the edge Getting ready to do the dash top with the 914Rubber kit. Pretty straightforward but my original material was too far gone to serve as a template and I have one question. I know the vinyl should run long over the step down in the dash metal to terminate underneath the dash pad when it is installed, but what about the foam? Should the foam also run under the dash pad a little or should it be trimmed even with the step? |
914_7T3 |
Jan 4 2019, 06:59 PM
Please forgive me, I'm new to all of this! Group: Members Posts: 1,853 Joined: 3-April 17 From: Los Angeles, CA Member No.: 20,991 Region Association: Southern California |
@bbrock
Brent, I believe that I still have my original vinyl from the install last month that you may use as a template. Would be happy to send it to you too along with a little bonus. Just hit me up with a PM. Thanks. |
bbrock |
Jan 4 2019, 11:39 PM
@bbrock Brent, I believe that I still have my original vinyl from the install last month that you may use as a template. Would be happy to send it to you too along with a little bonus. Just hit me up with a PM. Thanks. Oh wow, what a kind and generous offer, but I'm afraid the deed is already done. Got the dash top and most of the face done this evening. |
tyfighter123 |
May 3 2019, 10:23 PM
Newbie Group: Members Posts: 41 Joined: 22-September 16 From: Grand Junction Member No.: 20,422 Region Association: Rocky Mountains |
What did you do to glue both the vinyl and the backing down?
rjames |
May 3 2019, 10:32 PM
I'm made of metal Group: Members Posts: 3,955 Joined: 24-July 05 From: Shoreline, WA Member No.: 4,467 Region Association: Pacific Northwest |
Looks great! (IMG:style_emoticons/default/smilie_pokal.gif)
ndfrigi |
May 3 2019, 10:55 PM
Advanced Member Group: Members Posts: 2,933 Joined: 21-August 11 From: Orange County Member No.: 13,474 Region Association: Southern California |
bbrock |
May 3 2019, 11:14 PM
What did you do to glue both the vinyl and the backing down? I forgot about this thread. I used Weldwood on both the vinyl and foam. It was pointed out to me that the dash will get pretty hot on a sunny day so the adhesive needs to be able to take it. Can't remember how Weldwood was rated other than I checked and it had a high enough temp rating to make me happy. (IMG:style_emoticons/default/beerchug.gif) |
tyfighter123 |
May 4 2019, 03:26 PM
Thanks for the reply!
Lo-Fi Version | Time is now: 8th June 2024 - 06:53 AM |
