FS 1975 Porsche 914 Electric, 914 Electric Conversion |
MCJ |
Jan 23 2019, 09:29 PM
I'm new here ... Group: Members Posts: 0 Joined: 9-June 14 From: Pasadena, CA Member No.: 17,462 Region Association: Southern California |
Sold!
$18,000. Cash or cleared check Will email pics on request Porsche 914 Electric Build Components Weight 2163 lbs. total, 1087 lbs. front, 1076 lbs. rear 23 kWh system HPEVs AC50, 71 HP, continuous 4,000 RPM, Max 10,000 RPM 1238-7601 Curtis Controller, 96 volts, 300-800 amps 36 CALB LiFePo4 batteries, 3.2 volts, 180 amp hours Elcon 6000 Charger Full charge 180 amp hours, 120 volts EV West controller chill plate and cooling kit Elcon DC/DC converter Andromeda Interface Display of RPM, Speed, Motor voltage, Motor temp, Controller temp, Amp hours, State of Charge voltage, BMS monitoring- average cell temp, maximum cell temp Orion Battery Management System with CanBus readout adapter Balanced flywheel Heavy duty clutch plate Engine/Trans adapter plate Rebuilt transmission by CMS with intermediate bearing plate upgrade Shift linkage bushings Heavy duty Rear shocks, springs, and bushings Heavy duty front struts and torsion rods Front sway bar Four 4-spoke Fuchs wheels with comp tires, Four Riviera wheels with street tires included BMW 320i front brake calipers ( 2X stock piston diameter, 2X stock brake pad surface area) 19mm master brake cylinder (17mm stock) Front brake rotors Front and rear wheel bearings |
matthepcat |
Jan 23 2019, 10:29 PM
Meat Popsicle Group: Members Posts: 1,462 Joined: 13-December 09 From: Saratoga CA Member No.: 11,125 Region Association: Northern California |
I can help you post pictures if you would like. PM me.
Lo-Fi Version | Time is now: 10th June 2024 - 01:29 AM |
