914 or 911 trailer Custom made special order, AS NEW, for low clearance cars, EZ load |
toolguy |
Feb 15 2019, 05:24 PM
Senior Member Group: Members Posts: 1,270 Joined: 2-April 11 From: San Diego / El Cajon Member No.: 12,889 Region Association: Southern California |
Used about 10 times for local Concours events. . Custom special order construction for low clearance cars. 17'4" overall length so it can fit in a standard 20 ft garage with the
car on it. Lightweight structural steel tube construction. EST weight is 1600 pounds. Double 3500 lb dropped axles w/ electric brakes. Axles are set back to accommodate tongue weight balance for rear engine vehicle. Deck tire rails are 13 foot long and 16 in wide. Outside of tire rails are 5'11 1/2 " and inside to inside is 39". 2 5/16 ball hitch. Rails were built with a gradual arch dropping in the rear 2" which allows for loading without high centering the cars chassis 5 ft load ramps and 2 spare wheels. Manual winch and tie down points at all 4 corners. Tie down as pictured [for a 914] are included. Front wind / rock shield is alum diamond plate which easily unbolts or swivel down as needed. Steel Diamond plate side decks with flush lighting, Fenders are lined. Tires are good to go with aluminum rims. Swivel wheeled tongue jack . Standard 7 pin trailer electrical connector with brake aux battery. Center section has indoor / outdoor boat carpet over plywood. Painted in charcoal metallic gray. Perfect condition throughout. California title and registration. Never left outside overnight and stored in garage always. $4750 in San Diego. Attached image(s) |
URY914 |
Feb 15 2019, 07:33 PM
I built the lightest 914 in the history of mankind. Group: Members Posts: 121,017 Joined: 3-February 03 From: Jacksonville, FL Member No.: 222 Region Association: None |
That could be the prettiest trailer I've ever seen. Nice job!
sixnotfour |
Feb 16 2019, 02:35 PM
914 Wizard Group: Members Posts: 10,434 Joined: 12-September 04 From: Life Elevated..planet UT. Member No.: 2,744 Region Association: Rocky Mountains |
raynekat |
Feb 16 2019, 06:32 PM
Advanced Member Group: Members Posts: 2,159 Joined: 30-December 14 From: Coeur d'Alene, Idaho Member No.: 18,263 Region Association: Pacific Northwest |
Man I'd love to have that trailer....just don't have any place to put.
This will be a great piece of equipment for someone. GLWTS (IMG:style_emoticons/default/beerchug.gif) |
mepstein |
Feb 16 2019, 06:51 PM
914-6 GT in waiting Group: Members Posts: 19,313 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
Man I'd love to have that trailer....just don't have any place to put. This will be a great piece of equipment for someone. GLWTS (IMG:style_emoticons/default/beerchug.gif) (IMG:style_emoticons/default/agree.gif) if I had the money, I would tell my brother in law in SD to pick it up for me. |
Lo-Fi Version | Time is now: 7th June 2024 - 03:34 AM |
