911 Wiper Motor Conversion, Thinking Out Loud |
914Sixer |
Feb 18 2019, 08:59 AM
914 Guru Group: Members Posts: 8,897 Joined: 17-January 05 From: San Angelo Texas Member No.: 3,457 Region Association: Southwest Region |
911 wiper motors are three speed and ours are two. I was thinking how to install the 3 speed wiper system. The motor is a direct bolt in. You use the down position (intermittent position) for speed one and use position 3 (one up from center) for two and position 4 for high. It would require the 5 wire switch used for intermittent wipers. If you use a 6 wire switch you could add electric washer.
Is my thinking flawed? Attached image(s) |
larryM |
Feb 18 2019, 02:42 PM
emoze Group: Members Posts: 891 Joined: 1-January 03 From: mid- California Member No.: 65 Region Association: Northern California |
interesting idea - at first, a "wow-gotta have it" tho't bursts forth on 2nd tho't - is it anymore powerful than the oem motor, or just more speeds? 3rd tho't - "why me?" i have diligently avoided driving my -6 in rain or cold for the past 28 yrs .... ".... i really don't need that!" (& it'd be 'way more work than i care to do for something of limited use) IF - if there was such a solution for the anemic wipers in my "square" Chevy truck or my NB Miata, ... that would be another matter - and yes, i continually search for those solutions |
914Sixer |
Feb 18 2019, 02:49 PM
Just thinking of using 1st speed to replace intermittent wiper. Not sure if 2 & 3 on the 911 motor are the same as the 914 one. Might be different speeds all together.
mepstein |
Feb 18 2019, 03:01 PM
914-6 GT in waiting Group: Members Posts: 19,307 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
I remember someone doing a write up with a boxster motor. Clay maybe?
Edit - http://www.914world.com/bbs2/index.php?sho...;hl=wiper+motor |
PanelBilly |
Feb 18 2019, 03:25 PM
914 Guru Group: Members Posts: 5,811 Joined: 23-July 06 From: Kent, Wa Member No.: 6,488 Region Association: Pacific Northwest |
And you were thinking it would be fun to pull out the old one?
Lo-Fi Version | Time is now: 1st June 2024 - 04:38 PM |
