Jack points., Putting this thing up on all fours. |
MiniStevieG |
Feb 20 2019, 06:28 PM
Member Group: Members Posts: 179 Joined: 25-January 19 From: Dallas, TX Member No.: 22,827 Region Association: Southwest Region |
Does this diagram serve as a good reference for jack points? I’m planning to have my 914 up on jack stands (with backup support of course) for a week or so while I do some work under it. Always nervous working under the car to be honest. Just want to be as safe as possible. Thanks for everything!!
914outlaw |
Feb 20 2019, 08:39 PM
Dave Group: Members Posts: 198 Joined: 2-June 10 From: Central, NJ Member No.: 11,800 Region Association: North East States |
Here’s a link for a search to previous posts. There are several and most have good points. Good luck and be safe.
Jacking posts Does this diagram serve as a good reference for jack points? I’m planning to have my 914 up on jack stands (with backup support of course) for a week or so while I do some work under it. Always nervous working under the car to be honest. Just want to be as safe as possible. Thanks for everything!! |
iankarr |
Feb 20 2019, 08:40 PM
The wrencher formerly known as Cuddy_K Group: Members Posts: 2,480 Joined: 22-May 15 From: Heber City, UT Member No.: 18,749 Region Association: Intermountain Region |
Def use the locking pin-type jack stands. The ratcheting ones have been known to drop if accidentally knocked.
MiniStevieG |
Feb 20 2019, 09:08 PM
Def use the locking pin-type jack stands. The ratcheting ones have been known to drop if accidentally knocked. Picked up double pin locking jack stands for additional peace of mind. Still intend to put my wheels under the car for additional support. Thanks for the feedback. |
MiniStevieG |
Feb 20 2019, 09:13 PM
Here’s a link for a search to previous posts. There are several and most have good points. Good luck and be safe. Jacking posts Does this diagram serve as a good reference for jack points? I’m planning to have my 914 up on jack stands (with backup support of course) for a week or so while I do some work under it. Always nervous working under the car to be honest. Just want to be as safe as possible. Thanks for everything!! Solid thank you!! |
bbrock |
Feb 20 2019, 09:16 PM
Just an FYI, jacking under the long oval under the firewall tends to mangle the floor pan if you don't use something to spread the weight out. It's plenty strong to support the car though.
Rand |
Feb 20 2019, 10:04 PM
If you need a quick way to get it up, the blue pill is simply a beam (4x4 or what have you) under the rear firewall. Crossways, gives you a good way to get her in the air with support and it balances well there. That's what she said.
EDIT: Don't do this if you want it on all fours. Sorry I missed that bit. This method is only to get the rear up. |
r_towle |
Feb 20 2019, 10:05 PM
Custom Member Group: Members Posts: 24,585 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States |
First time, jack under the rear trailing arms and put jack stands underneath those, then the same up front.
So use the suspension first, that already holds up the car. Then get under there and inspect everything to determine where you can safely support the car. This is coming from someone who has bought and stripped a few of these in rough shape. |
MiniStevieG |
Feb 22 2019, 02:47 PM
What about jack points here?
Or here? |
jkb081 |
Oct 30 2021, 11:18 PM
Member Group: Members Posts: 78 Joined: 24-October 21 From: San Francisco, CA. Member No.: 26,018 Region Association: Northern California |
Got it! Thanks!
mlindner |
Oct 31 2021, 08:20 AM
Senior Member Group: Members Posts: 1,526 Joined: 11-November 11 From: Merrimac, WI Member No.: 13,770 Region Association: Upper MidWest |
Use 2 x 6's flat on bottom of car from front pinch weld and donut to rear donut/pinch weld. Jack stands on both ends....spreads weight out well and is very stable. Best, Mark
Dave_Darling |
Oct 31 2021, 01:38 PM
The intent of the long ovals was to show that you wanted something that would span much of that to spread out the load.
Suspension mounting points are good, if they're solid. The engine mount bar is very convenient to use, but the bar is held onto the chassis by four M8 bolts, so you might want to be wary of that. --DD |
bkrantz |
Oct 31 2021, 07:49 PM
914 Guru Group: Members Posts: 7,792 Joined: 3-August 19 From: SW Colorado Member No.: 23,343 Region Association: Rocky Mountains |
Def use the locking pin-type jack stands. The ratcheting ones have been known to drop if accidentally knocked. Picked up double pin locking jack stands for additional peace of mind. Still intend to put my wheels under the car for additional support. Thanks for the feedback. Good idea about putting the wheels under the car. I always do that as backup to jack stands. |
Lo-Fi Version | Time is now: 2nd June 2024 - 01:15 AM |
