> Suspension Ear Jig, Now with purchase and rental info
McMark
post Feb 26 2019, 09:00 AM
914 Freak!
I made this jig as parts of my Celette bench project, specifically with this yellow car in mind. Finally got to doing the work and this beauty worked perfectly. I'm also surprised by just how far off it would have been by just lining up the new metal with the old. This is inevitable with reproduction parts. But that's just part of the game. Now I know and now I've got the jig to make doing it right a lot easier.
Purchase and Rental:
1. Rental: These will be rentable for $100 for 2 weeks, $150 for a month.
2. Purchase: To own a set, it'll be $350 for the pair or $250 for just the right side.
These will take me 2-3 weeks to assemble and ship.
Replies(1 - 19)
post Feb 26 2019, 09:21 AM
914-6 GT in waiting
Would you be willing to make some for sale?
I’ll send money as soon as you come up with a price.
@McMark
post Feb 26 2019, 10:26 AM
That is an excellent idea. I'm surprised it hasn't been done before. Every time I read a thread re: replacing that suspension ear I think about how critical that dimension is and how easily it could be attached incorrectly. Great addition to your tool box and the 914 community. (IMG:style_emoticons/default/beerchug.gif)
Olympic 914
post Feb 26 2019, 10:56 AM
Wouldn't you need two? A right and a left.
McMark
post Feb 26 2019, 11:01 AM
914 Freak!
Mark, I'll look into it and let you know.
QUOTE(Olympic 914 @ Feb 26 2019, 11:56 AM) *
I have two... (IMG:style_emoticons/default/beerchug.gif)
Yes, they're different for left and right.
bbrock
post Feb 26 2019, 11:10 AM
I would have bought one of these when I was doing mine. Would that jig also work in reverse to locate the outer suspension console from a correctly positioned ear?
post Feb 26 2019, 11:42 AM
914-6 GT in waiting
Yes if needed. Most of the time it’s the right/passenger suspension consoles that went bad because rain water washing over the battery and down to the suspension accelerated the right side damage.
enf2232
post Feb 26 2019, 06:16 PM
Since I was the Guinea Pig do I get a cut of the action? (IMG:style_emoticons/default/biggrin.gif)
McMark
post Feb 27 2019, 03:01 PM
914 Freak!
QUOTE(bbrock @ Feb 26 2019, 12:10 PM) *
I would say No, it's won't work that way. The outer section is very accurate due to having three mounting holes. The jig is self aligning when mounted on the outer. To do the reverse, you would have to spend more time ensuring the accuracy, because the single mounting hole would allow for quite a bit of movement and essentially infinite rotation options. Also, the outer holes must be in the correct PLANE to be accurate. The inner hole simply has to be at the correct POINT in space. As long as the pivot shaft bolt goes through the hole, it's correct. But that being said, it wouldn't be too difficult to add a third branch to include the motor mount and then I'd have a jig that could be used for inner, outer, OR motor mount replacement with confidence. (IMG:style_emoticons/default/idea.gif)
QUOTE(enf2232 @ Feb 26 2019, 07:16 PM) *
I'll make sure your residuals get forwarded to you. Just don't go shopping for swimming pools just yet.
(IMG:http://www.914world.com/bbs2/uploads_offsite/dinosaurdracula.com-419-1551301291.1.jpg)
(IMG:style_emoticons/default/av-943.gif)
bretth
post Feb 27 2019, 03:20 PM
Very nice work.
BTW the subject of this thread sounds like a song one could dance to. (IMG:style_emoticons/default/biggrin.gif)
914forme
post Feb 28 2019, 09:00 PM
I would love a set also, I have a set from Tangerine Racing from the raised pickup point kit.
PatrickB
post Mar 1 2019, 04:27 AM
QUOTE(McMark @ Feb 27 2019, 05:01 PM) *
I might be interested depending on price.. I'm thinking I might need a set down the road.
rick 918-S
post Mar 1 2019, 05:28 AM
Hey nice rack! -Celette
After I picked up the fixture set you made for me I received an email from a local MN member wanting me to fix a cracked suspension ear on his race car. So put me down for a set and send them with that long repair panel I forgot to grab.
BTW fellas, I had eyes on that jig. It's a nice piece.
jtprettyman
post Mar 1 2019, 11:54 AM
Rust Bucket Owner
That's a great explanation of GD&T in a practical, real-world application there.
johnhora
post Mar 1 2019, 01:31 PM
QUOTE(mepstein @ Feb 26 2019, 08:21 AM) *
@McMark
(IMG:style_emoticons/default/agree.gif) ....DITTO
Only other requirement I have is you put your cool logo on it like my other tool (IMG:style_emoticons/default/biggrin.gif)
BeatNavy
post Mar 1 2019, 01:34 PM
Mark, I would probably be up for one as well.
McMark
post Mar 4 2019, 08:12 AM
914 Freak!
I worked up pricing on making these and here's how it'll break down:
post Mar 4 2019, 08:24 AM
914-6 GT in waiting
QUOTE(McMark @ Mar 4 2019, 09:12 AM) *
I'll take a pair. Edit - Just paid. I doubt I would need to replace the driver side but at the very least, it will make a nice jig to check alignment of the console. No rush and thanks for doing these. (IMG:style_emoticons/default/beerchug.gif)
Luke M
post Mar 4 2019, 03:08 PM
I would say No, it's won't work that way. The outer section is very accurate due to having three mounting holes. The jig is self aligning when mounted on the outer. To do the reverse, you would have to spend more time ensuring the accuracy, because the single mounting hole would allow for quite a bit of movement and essentially infinite rotation options. Also, the outer holes must be in the correct PLANE to be accurate. The inner hole simply has to be at the correct POINT in space. As long as the pivot shaft bolt goes through the hole, it's correct. But that being said, it wouldn't be too difficult to add a third branch to include the motor mount and then I'd have a jig that could be used for inner, outer, OR motor mount replacement with confidence. idea.gif
Hi Mark,
I have a question about this. I'm going to be replacing the whole right long with a factory part and want to make sure all is well prior to welding it in. My question is you mentioned using a third point for reference. In my case it's going into a factory 6 so there's no engine mounts next to the inner ear. I know there's a factory measurements from the firewall to the inner ear. What would your thoughts be on this.
I have a jig/frame built to hold the chassis but that doesn't mean that things are within factory specs. I would rather install it correctly the first time then have to redo it. Measure a 100 times weld once.. I maybe in for a set of these as well.
McMark
post Mar 5 2019, 02:44 PM
914 Freak!
A replacement that large really should be on the Celette bench.
But if you're gonna go without I could make a version where the left and right are attached together. That's still no guarantee things are in the right place though. Going from left to right is a pretty long piece. So small variations get compounded. So if you're basing everything off the left and that's off by 1°, that'll translate to the right being off 25mm or 1". (IMG:style_emoticons/default/yikes.gif) So honestly, I feel like I'd be giving you false confidence.
The big scary part is what I mentioned in the original post. The replacement panels don't necessarily match perfectly. Original pieces may be better, but at this point I'd have a hard time trusting any replacement metal. So if you just line things up, you may feel confident, but it may not be right just because the pieces lined up. (IMG:style_emoticons/default/sad.gif) (IMG:style_emoticons/default/sad.gif) (IMG:style_emoticons/default/sad.gif)
- Lo-Fi Version Time is now: 2nd April 2026 - 11:17 AM
