billium01 |
Member ![]() ![]() Group: Members Posts: 136 Joined: 12-April 13 Member No.: 15,764 Region Association: None ![]() |
Hello thanks for looking. Gonna replace the front trunk floor pan and the panel that the front bumper attaches too. Restoration designs calls it the "latch panel". On the picture I posted it's panel number 13. Any advice on doing this without a celette bench?
Thanks Bill ![]() ![]() |
r_towle |
Custom Member ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 24,594 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States ![]() ![]() |
You need to hold the car in place somehow.
Build a frame out of tall (in profile) boxed steel, or I beams. Weld stands from that to both sides...so a piece of square tubing the same length from the ibeam to the rear firewall seam. Basically, attach the car, parallel and ideally level to the beam. |
billium01 |
You need to hold the car in place somehow. Build a frame out of tall (in profile) boxed steel, or I beams. Weld stands from that to both sides...so a piece of square tubing the same length from the ibeam to the rear firewall seam. Basically, attach the car, parallel and ideally level to the beam. Thanks! Appreciate it. Ended up buying one of these. Looks like it'll work ok huh? ![]() |
914werke |
"I got blisters on me fingers" ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 10,157 Joined: 22-March 03 From: USofA Member No.: 453 Region Association: Pacific Northwest ![]() ![]() |
Does the replacement "pan" already have the front suspension mounts & rear tube mounts installed?
billium01 |
Does the replacement "pan" already have the front suspension mounts & rear tube mounts installed? ![]() No it does not. I bought the suspension mounts and reinforcement metal as well though. The rear front suspension cross member attachment points will remain in place. Very nice piece from restoration designs I might ad. Something I should watch out for? |
Mark Henry |
that's what I do! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 20,065 Joined: 27-December 02 From: Port Hope, Ontario Member No.: 26 Region Association: Canada ![]() |
RD also has the front A-arm mounts for the pan.
Make a jig like stoddarts before you start, cut out all of the old part and the pan centers itself, then use the jig to weld in the front A-arm mounts. If you have a scrap set of A-arms you could use them as part of your jig. My son has that same RD piece and the mounts for his project, please post a thread on your pan replacement when you do the deed. |
Lo-Fi Version | Time is now: 17th June 2024 - 05:09 AM |
