Raising the window, Gap when windows closed |
cal914 |
Mar 11 2019, 11:05 AM
Member Group: Members Posts: 319 Joined: 12-April 12 From: United Kingdom Member No.: 14,366 Region Association: None |
76-914 |
Mar 11 2019, 11:49 AM
Repeat Offender & Resident Subaru Antagonist Group: Members Posts: 13,509 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California |
When my drivers side window is shut theres a gap along the top of the window as shown in the pic ,is there a way of raising the frame and the glass Thanks B Yes. 1st a question though. Is the gap size consistent across the top? (IMG:style_emoticons/default/beerchug.gif) |
VaccaRabite |
Mar 11 2019, 11:55 AM
En Garde! Group: Admin Posts: 13,465 Joined: 15-December 03 From: Dallastown, PA Member No.: 1,435 Region Association: MidAtlantic Region |
My car has the same exact gap. I'd love to know how to fix it.
Zach |
mepstein |
Mar 11 2019, 12:00 PM
914-6 GT in waiting Group: Members Posts: 19,314 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
You can adjust the window. There's a thread or 10 on World. Google - 914world.com window adjustment and you will get all the info you need.
BeatNavy |
Mar 11 2019, 12:35 PM
You can adjust the window. There's a thread or 10 on World. Google - 914world.com window adjustment and you will get all the info you need. (IMG:style_emoticons/default/agree.gif) Lots of "how-to" threads. The challenge is determining what you actually need to do, as there are LOTS of variables to getting your window positioned correctly, such as actual structural integrity, door placement, condition and placement of all seals and of the roof, and the interior door mechanicals. If your only problem is that the window isn't raising high enough, IIRC you adjust the window travel with the threaded rod on underside of door closest to hinge. Unlock the lock nut and use a flat tip screw driver to change the amount of travel. That's on early cars. Not sure about late. If that doesn't solve the problem, I'd also check inside the door to see if you have the window "button" in the slider. Those break, and then the window tends to sag. |
lierofox |
Mar 12 2019, 10:10 PM
Member Group: Members Posts: 256 Joined: 23-June 15 From: Paso Robles, CA Member No.: 18,880 Region Association: Southern California |
If your only problem is that the window isn't raising high enough, IIRC you adjust the window travel with the threaded rod on underside of door closest to hinge. Unlock the lock nut and use a flat tip screw driver to change the amount of travel. That's on early cars. Not sure about late. Later models have an adjustment bolt/lock-nut on the regulator. The part labeled "C" on this post. |
horizontally-opposed |
Mar 12 2019, 10:42 PM
Advanced Member Group: Members Posts: 3,432 Joined: 12-May 04 From: San Francisco Member No.: 2,058 Region Association: None |
Definitely adjustable, and may even be easy—but as others have alluded to, it's a matter of a number of adjustments.
This is the thread that helped me most: http://www.914world.com/bbs2/index.php?sho...p;#entry2000174 |
Lo-Fi Version | Time is now: 8th June 2024 - 09:44 PM |
