FS new master cylinders 19mm $95 |
Mikey914 |
Mar 19 2019, 11:05 PM
The rubber man Group: Members Posts: 12,671 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None |
So the majority of the master cylinders we've been selling are the easy option, so we have put the non-easy on sale. Just like stock, 19mm master cylinders. It's either this or disassemble, re-machine (for the easy kit), reassemble, and test.
Thanks to all! Mark https://900designs-container.zoeysite.com/1...er-cylinder-2-1 Attached image(s) |
db9146 |
Mar 20 2019, 08:00 AM
Senior Member Group: Members Posts: 953 Joined: 21-December 04 From: Atlanta, GA Member No.: 3,315 Region Association: None |
Do these come with the washers for underneath the grommets?
Any idea how these compare with the ATE brand? |
bdstone914 |
Mar 20 2019, 08:21 AM
bdstone914 Group: Members Posts: 4,524 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 |
Do these come with the washers for underneath the grommets? Any idea how these compare with the ATE brand? @db9146 Yes the washers are included. Compared to Ate they are functionally the same and about half the price. The Ate 17mm costs more than the 19mm. The stock 914 master was17mm. The 914-6 was 19mm. Most agree that the change from 17mm to 19mm is barely noticeable. You will have slightly reduced pedal travel and a firmer feel if you are replacing a 17mm master. Bruce |
914Sixer |
Mar 20 2019, 08:28 AM
914 Guru Group: Members Posts: 8,887 Joined: 17-January 05 From: San Angelo Texas Member No.: 3,457 Region Association: Southwest Region |
ATE have been NLA for sometime. Very hard to find.
roblav1 |
Mar 20 2019, 08:54 AM
Senior Member Group: Members Posts: 528 Joined: 18-September 12 From: KY Member No.: 14,943 Region Association: MidAtlantic Region |
So these have a brake pressure sensor to run the brake lights rather than the mechanical switch? Is there enough material at the rubber connections to tap a useable thread for an adapter?
Mikey914 |
Mar 20 2019, 11:47 PM
You are welcome to try to tap the upper ports, but there is the possibility of getting material into unit. We do ours before assembly, and if we were to do this (tap the no tapped versions we made) we would not do it assembled.
It would be easier to just buy the "easy" kit which we have done this already and include the machined nipples and hydraulic hose to splice into the existing lines. |
Specracer |
Mar 21 2019, 05:47 AM
Member Group: Members Posts: 100 Joined: 27-March 17 From: SE Mass Member No.: 20,970 Region Association: None |
Itsnt timing everything, 20 days ago, bought said item for $145...
Lo-Fi Version | Time is now: 23rd May 2024 - 10:52 AM |
