| shuie |
Mar 24 2019, 06:38 PM
Member ![]() ![]() Group: Members Posts: 352 Joined: 17-May 04 From: baton rouge, la Member No.: 2,075 |
I'm looking for a flat tow hook that mounts over the front torsion bar end cap pickup point. The guy who makes these is a member here and I cannot remember his name. I'm trying to find his site or contact info so I can order another one. I bought one from him years ago for my 914 and need another one for a different car.
The one I'm looking for is very similar to the one in the rennline link below, except the tow hook/tie down loop is flat and extends out under the front bumper, instead of being welded to the plate that goes over the torsion bar cap at a 90 degree angle. http://www.rennline.com/Rennline-Front-Tow...roductinfo/E03/ Does this sound familiar to anyone? Does anyone remember who makes the flat one I'm talking about? TIA |
| DickSteinkamp |
Mar 24 2019, 09:43 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 500 Joined: 27-February 17 From: Bellingham, WA Member No.: 20,876 Region Association: None |
| shuie |
Mar 25 2019, 12:07 PM
not the same product, but I think dlee1967 is the guy who made the tow hook I am looking for. Thanks again!
| maf914 |
Mar 26 2019, 06:40 AM
Not a Guru! ![]() ![]() ![]() ![]() Group: Members Posts: 3,049 Joined: 30-April 03 From: Central Florida Member No.: 632 Region Association: None
| mepstein |
Mar 26 2019, 07:09 AM
914-6 GT in waiting ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 20,923 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region
A tow hook is different from a tow bar. If they are not currently being made. I bet Ben/MB911 could easily have some made. @MB911
@shuie Attached image(s)
| Mikey914 |
Mar 26 2019, 07:14 AM
The rubber man ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 12,784 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None
I Make the tow bar , just not the hooks you are looking for sorry,
Mark |
| mepstein |
Mar 26 2019, 07:27 AM
I Make the tow bar , just not the hooks you are looking for sorry, Mark I have a 914rubber tow bar. I purchased it so I can get a tow home if my car gives out while i'm doing some shakedown runs. I can keep the bar mounted on the front and the trailer part in the trunk. Cheap insurance. |
| Mikey914 |
Mar 26 2019, 07:42 AM
We flat to to events (WCR) the wife can't stand too many hours of open road noise. Best way to go so if the car has an issue you know you can get it home easily.
| mb911 |
Mar 26 2019, 07:49 AM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,813 Joined: 2-January 09 From: Burlington wi Member No.: 9,892 Region Association: Upper MidWest
I am going to make some of these. I just have to decide how to clear the valance. Should be pretty straightforward
| DRPHIL914 |
Mar 26 2019, 09:19 AM
Dr. Phil ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,971 Joined: 9-December 09 From: Kennesaw, GA Member No.: 11,106 Region Association: South East States
I am going to make some of these. I just have to decide how to clear the valance. Should be pretty straightforward I would be in for this, I want something that would allow for not modifying the stock front valance. Saves on the weight of a trailer, I have towed with 4 wheels down with a motor home before, used a blue ox tow bar, had the mount brackets bolted to the front of a 4x4 suburban and my car too back then. if you make the brackets to bolt to the 914 rubber bar that can go under the valance I will get one for sure!. Lets do this before Okteenerfest! |
| mepstein |
Mar 26 2019, 09:45 AM
Phil - I'm not sure this makes a good tie down, if that's what you have in mind. Usually, you want to tie down to the suspension. The car body will move up and down on a trailer while the wheels and suspension will stay firm. My comment about Mikey's tow bar wasn't meant to imply this was a fitting to his product. If I'm getting this wrong, please disregard.
| Andyrew |
Mar 26 2019, 11:15 AM
Spooling.... Please wait ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 13,381 Joined: 20-January 03 From: Riverbank, Ca Member No.: 172 Region Association: Northern California
How many of you flat tow guys use a brake system? (You know, like the law requires....)
| Chris914n6 |
Mar 26 2019, 01:42 PM
Jackstands are my life. ![]() ![]() ![]() ![]() Group: Members Posts: 3,556 Joined: 14-March 03 From: Las Vegas, NV Member No.: 431 Region Association: Southwest Region |
How many of you flat tow guys use a brake system? (You know, like the law requires....) Tow dollys don't have brakes, so must be well within weight limits (IMG:style_emoticons/default/poke.gif) |
| sixnotfour |
Mar 26 2019, 01:50 PM
914 Wizard ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 11,377 Joined: 12-September 04 Member No.: 2,744 Region Association: NineFourteenerVille
QUOTE How many of you flat tow guys use a brake system? (You know, like the law requires....) Ca. and Idaho only states that require brakes 1500lbs and above, others 3000lbs,some must be able to stop in a legal distance,and or have an adequate park brake |
Lo-Fi Version | Time is now: 3rd October 2026 - 12:40 AM |
