shift rod at shifter hitting clutch tube getting into 4th gear, where should clutch tube be in relation of shifter in tunnel? |
buck toenges |
Mar 26 2019, 06:39 AM
Senior Member Group: Members Posts: 553 Joined: 25-November 03 From: Fort wayne In Member No.: 1,388 Region Association: None |
My clutch cable tube is disconnected at the front part of the tunnel. I repaired it by hooking up a "O" bolt around the tube and secured to the driver side of the tunnel. The shifter connection to the shift rod hits the clutch cable tube when going into 4th gear from 3rd gear. It does the same thing when getting out of 4th or 5th back to 3rd.
Where should the clutch cable tube be in relationship to the shifter? Should the tube be below the shifter or to the driver side of the shifter? Thanks, Buck |
76-914 |
Mar 26 2019, 08:58 AM
Repeat Offender & Resident Subaru Antagonist Group: Members Posts: 13,509 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California |
My clutch cable tube is disconnected at the front part of the tunnel. I repaired it by hooking up a "O" bolt around the tube and secured to the driver side of the tunnel. The shifter connection to the shift rod hits the clutch cable tube when going into 4th gear from 3rd gear. It does the same thing when getting out of 4th or 5th back to 3rd. Where should the clutch cable tube be in relationship to the shifter? Should the tube be below the shifter or to the driver side of the shifter? Thanks, Buck Low and to the drivers side of shifter (IMG:style_emoticons/default/beerchug.gif) |
bdstone914 |
Mar 26 2019, 09:06 AM
bdstone914 Group: Members Posts: 4,537 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 |
sixnotfour |
Mar 26 2019, 09:24 AM
914 Wizard Group: Members Posts: 10,436 Joined: 12-September 04 From: Life Elevated..planet UT. Member No.: 2,744 Region Association: Rocky Mountains |
here is a recent thread with some pics
http://www.914world.com/bbs2/index.php?sho...36124&st=20 |
dr914@autoatlanta.com |
Mar 26 2019, 09:28 AM
914 Guru Group: Members Posts: 7,896 Joined: 3-January 07 From: atlanta georgia Member No.: 7,418 Region Association: None |
This is a common problem that has been plaguing 914s since they were a few years old. BASICALLY the tube has to be realigned under its u bracket, and you can see by putting your cheek to the center tunnel and looking forward where the tube used to by by its lack of paint, so since it usually pulls forward, you just pull it backwards realigning it against the left inside of the center tunnel and re weld. It is a fairly easy fix if you can weld, but have to avoid the fuel lines. There are many diagrams out there on the internet as well as in the back of my book "tech tips 700" and the procedure of how to do it
My clutch cable tube is disconnected at the front part of the tunnel. I repaired it by hooking up a "O" bolt around the tube and secured to the driver side of the tunnel. The shifter connection to the shift rod hits the clutch cable tube when going into 4th gear from 3rd gear. It does the same thing when getting out of 4th or 5th back to 3rd. Where should the clutch cable tube be in relationship to the shifter? Should the tube be below the shifter or to the driver side of the shifter? Thanks, Buck |
Lo-Fi Version | Time is now: 9th June 2024 - 09:53 PM |
