Hub inner wheel bearing seal, Which side is which? |
jfort |
Apr 5 2019, 03:27 PM
Senior Member Group: Members Posts: 1,137 Joined: 5-May 03 From: Findlay, OH Member No.: 652 Region Association: Upper MidWest |
The seal apparently has an inner and an outer side. On one side the rubber has a sharp edge that extends a little beyond the flat side of metal. Does that side go next to the bearing or go toward the suspension ? It may be clear when I remove the current seal but I thought I’d ask. Thanks in advance as I want to get this done tomorrow.
iankarr |
Apr 5 2019, 09:54 PM
The wrencher formerly known as Cuddy_K Group: Members Posts: 2,481 Joined: 22-May 15 From: Heber City, UT Member No.: 18,749 Region Association: Intermountain Region |
If it’s what I think you’re describing, the rubber ring is a separate piece that’s flat on the suspension side. There’s a front wheel bearing install video on my YouTube channel. Hope it helps! Link below...
jfort |
Apr 6 2019, 04:56 PM
It runs out that it is easy to see how it goes based on the one in place. The pointy ruined side is out, the smooth side toward the bearing. Packed all the bearings. New pads and rotors up front. Bled them again. Bedded the rotors and pads. All works great. Ready for 5/13 track day at Mid Ohio.
wndsrfr |
Apr 7 2019, 05:35 AM
Senior Member Group: Members Posts: 1,430 Joined: 30-April 09 From: Rescue, Virginia Member No.: 10,318 Region Association: MidAtlantic Region |
It runs out that it is easy to see how it goes based on the one in place. The pointy ruined side is out, the smooth side toward the bearing. Packed all the bearings. New pads and rotors up front. Bled them again. Bedded the rotors and pads. All works great. Ready for 5/13 track day at Mid Ohio. Give us a report on your M.O. event...I'm currently at VIR race with VDCA/VRG...Michael S. is here also...we're grouped with Mustang Camaro Alfa 240 Z's...having a blast.... |
Lo-Fi Version | Time is now: 8th June 2024 - 06:02 AM |
