Detailed MFI pictures |
Bob Wolcott |
Jun 23 2005, 08:34 PM
Member Group: Members Posts: 85 Joined: 18-May 05 From: McMinnville, OR Member No.: 4,096 |
Does anyone have detailed pictures of an engine with MFI. I'm looking for some that would show how the various linkage components are oriented.
Thanks, Bob |
michel richard |
Jun 23 2005, 08:46 PM
Senior Member Group: Members Posts: 1,291 Joined: 22-July 03 From: Longueuil, Québec Member No.: 936 |
I can put some up in the morning.
Michel Richard 914/6 (conversion) 2.2 E MFI |
xitspd |
Jun 23 2005, 09:44 PM
Technology and Tradition 3.6 and 914-6 Group: Members Posts: 1,305 Joined: 17-November 04 From: Foothills of Mt. San Jacinto, CA Member No.: 3,136 |
This is the MFI motor in my 1974 Carrera.
Attached image(s) |
ArtechnikA |
Jun 24 2005, 12:18 AM
ClayPerrine |
Jun 24 2005, 06:48 AM
Life's been good to me so far..... Group: Admin Posts: 15,507 Joined: 11-September 03 From: Hurst, TX. Member No.: 1,143 Region Association: NineFourteenerVille |
michel richard |
Jun 24 2005, 07:07 AM
engine in the car
Attached image(s) |
michel richard |
Jun 24 2005, 07:08 AM
clutch end
Attached image(s) |
michel richard |
Jun 24 2005, 07:10 AM
As for the previous image: The stock intake does not fit with MFI in he 914. Normally, the intake is turned around to fit a 914, but you can't do that with MFI because the underside of the filter assembly then fouls the pump.
More pictures: Attached image(s) |
michel richard |
Jun 24 2005, 07:11 AM
more
Attached image(s) |
michel richard |
the pump
Attached image(s) |
michel richard |
pump again
Attached image(s) |
michel richard |
Jun 24 2005, 07:16 AM
You have to remove the trunk springs, otherwise, they foul the pump.
Attached image(s) |
ClayPerrine |
Jun 24 2005, 07:23 AM
I didn't have to remove the torsion bars for the trunk. All I had to do was to point one banjo fitting down slightly to get the pump to clear the torsion bars. What year is that motor? There may be some difference in years . Sorry, no picts. I am at work. |
michel richard |
Jun 24 2005, 01:01 PM
The engine is a 2.2E built on a 5R 2.4 case. Short stroke counterweighted crank, 2.2 rods E pistons, heads and cams.
michel richard |
Jun 24 2005, 01:39 PM
OK, good to know. I'll be putting that engine in another car in a few months time, I'll keep the springs then. Oh, and the MFI is a 2.2E pump with magnesium stacks and 2.2 E throttle bodies. Michel |
ClayPerrine |
Jun 24 2005, 01:43 PM
Mine is a 73 with the plastic stacks and the 73 pump. I wonder if that makes a difference?
michel richard |
Jun 24 2005, 03:25 PM
I'm trying to think back about exactly what was actually fouling when I was putting the engine in. Not sure.
I'll try and see if I can put the springs back in with the engine and injection already in the car. Seriously doubt that I can, though. Cheers. Michel |
Bob Wolcott |
Jun 24 2005, 06:49 PM
I really appreciate the help.
Thanks! Bob |
Lo-Fi Version | Time is now: 4th June 2024 - 02:17 PM |
