interior cleaning, Vacuum your roof ? |
rgalla9146 |
Apr 12 2019, 05:44 PM
Advanced Member Group: Members Posts: 4,569 Joined: 23-November 05 From: Paramus NJ Member No.: 5,176 Region Association: None |
Check the difference.
Attached thumbnail(s) |
Tom_T |
Apr 12 2019, 05:52 PM
After you get it all vacuumed off, then try some Folex on the spots & edge browning (test on a corner first). Spray on, soak 5 mins (longer if stubborn), then dab off with a soft absorbent cotton cloth like an old t-shirt, towel, etc.; & you may need to do it a couple of times with stubborn spots/staining. You don't want to rub nor brush that mousefur perlon in the headliner nor carpet, because it will make it unravel &/or "pill".
You can also use it on the carpet, if you're saving that too. Folex is sold in gals & qt spray bottles at Home Depot etc., or order online from Waxie in Santa Ana CA. I was able to pull 25-30 years of camping, coffee & cokes, & other kids grime off of our `88 Westfalia's upholstery & plush carpet with it, & it looks as new! (IMG:style_emoticons/default/smile.gif) (IMG:style_emoticons/default/beerchug.gif) Tom /////// |
rgalla9146 |
Apr 12 2019, 07:57 PM
After you get it all vacuumed off, then try some Folex on the spots & edge browning (test on a corner first). Spray on, soak 5 mins (longer if stubborn), then dab off with a soft absorbent cotton cloth like an old t-shirt, towel, etc.; & you may need to do it a couple of times with stubborn spots/staining. You don't want to rub nor brush that mousefur perlon in the headliner nor carpet, because it will make it unravel &/or "pill". You can also use it on the carpet, if you're saving that too. Folex is sold in gals & qt spray bottles at Home Depot etc., or order online from Waxie in Santa Ana CA. I was able to pull 25-30 years of camping, coffee & cokes, & other kids grime off of our `88 Westfalia's upholstery & plush carpet with it, & it looks as new! (IMG:style_emoticons/default/smile.gif) (IMG:style_emoticons/default/beerchug.gif) Tom /////// Thanks for the suggestions Tom Coincidentally, I have an '89 Westy ! The interior is very clean but I'll put Folex on my to do list. |
Lo-Fi Version | Time is now: 8th June 2024 - 02:02 PM |
