cashiersjm |
Member ![]() Group: Members Posts: 40 Joined: 6-December 09 From: Cashiers, North Carolina Member No.: 11,100 Region Association: South East States ![]() ![]() |
I had air & water leaking around my front windshield, the butyl was old and not adhering to the the metal frame. Easily removed the windshield, without cracking, but can't find anything to remove the old butyl other than a razor blade. Any suggestions?
UROpartsman |
Member ![]() ![]() Group: Members Posts: 295 Joined: 22-October 15 From: Simi Valley, CA Member No.: 19,288 Region Association: None ![]() ![]() |
Scrap off as much as you can, and then old rags and mineral spirits?
76-914 |
Repeat Offender & Resident Subaru Antagonist ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 13,735 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California ![]() ![]() |
A ball of butyl. Dap at it. The stuff on the dash will adhere to the ball of butyl in your hand as you dab at it. (IMG:style_emoticons/default/beerchug.gif)
rhodyguy |
Chimp Sanctuary NW. Check it out. ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 22,248 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch ![]() |
Heat will help soften. More hair dryer than heat gun. Like the glue on the engine firewall. A tedious chore. Fortunate you saved the windshield.
cashiersjm |
Fortunately the butyl was so old, the windshield came out without any resistance. There was little butyl left in the window frame, it was all on the glass. I used a section of foam pipe insulation to cushion one side of the glass while working on the remainder and so far, no cracks. Just that the old butyl is really stuck to the glass. Thanks for the suggestions.
Mikey914 |
The rubber man ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 12,772 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None ![]() ![]() |
Goof off may be your best option.
rhodyguy |
Missed the glass.
Mark Henry |
that's what I do! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 20,065 Joined: 27-December 02 From: Port Hope, Ontario Member No.: 26 Region Association: Canada ![]() |
Mikey914 |
Just carve off as much as you can 1st.
iankarr |
The wrencher formerly known as Cuddy_K ![]() ![]() ![]() ![]() Group: Members Posts: 2,561 Joined: 22-May 15 From: Heber City, UT Member No.: 18,749 Region Association: Intermountain Region ![]() ![]() |
Scrap off as much as you can, and then old rags and mineral spirits? (IMG:style_emoticons/default/agree.gif) Use anotehr piece of butyl to grab what's on the frame. Then lots of rags and mineral spirits did the trick for me. |
cashiersjm |
Well, the razor blade & mineral spirits worked the fastest and best, thanks.
Now the usual "while I'm doing this, I might as well do....." so next question: while the windshield is out, how difficult is it to replace the rubber gasket along the bottom of the windshield. I found a little surface rust and it would be much easier to clean up if the gasket was out. Of course then I will need a new 914Rubber replacement gasket. |
iankarr |
The rubber is easy to replace with the glass out. It’s also a great time to refurb the upper dash and dash cap.
cashiersjm |
Thanks, the dash & cap are great, Craig @ Camp914 did those back in "15 when I bought the car. Now ordering the windshield rubber. Seems like I never run out of little things to fix. Happy Easter All.
Lo-Fi Version | Time is now: 4th July 2025 - 10:41 AM |
