Russel's hard tube adapters for An-6, no flare tool needed/ crimp on.. |
ClayPerrine |
Jun 24 2005, 11:45 AM
Life's been good to me so far..... Group: Admin Posts: 15,526 Joined: 11-September 03 From: Hurst, TX. Member No.: 1,143 Region Association: NineFourteenerVille |
What was this thread SUPPOSED to be?
(IMG:http://www.914world.com/bbs2/html/emoticons/confused24.gif) |
phantom914 |
Jun 24 2005, 11:59 AM
non-914-owner non-club member Group: Benefactors Posts: 1,013 Joined: 24-February 04 From: Covina,CA(North ofWest Covina) Member No.: 1,708 |
Deleted? Andrew |
Mueller |
Jun 24 2005, 12:03 PM
bummer, I wanted to know how well these work, I was thinking of trying them out............
Britain Smith |
Jun 24 2005, 12:09 PM
Nano Member Group: Members Posts: 2,354 Joined: 27-February 03 From: Hillsboro, OR Member No.: 364 |
They have a max pressure of something like 25psi or something. I looked into them and determined that they were not acceptable for high fuel pressure. I ended up borrowing a 37degree flaring tool and doing it correctly.
-Britain |
DougC |
Jun 24 2005, 12:24 PM
Senior Member Group: Members Posts: 949 Joined: 6-July 04 From: Dallas, TX Member No.: 2,307 |
Sorry guys, the server (or something) was acting up when I originally tried to post the message.."Fatal Error, timeout" I think it said. But, basically I was wondering how well they worked because I don't have a flaring tool and wanted to try them. BUT, I'll be using CIS in a 2.7 and they run lots of pressure so I guess this may not be for me..
Doug C |
ArtechnikA |
Jun 24 2005, 04:17 PM
have you thought of these ?
when used with the tube nut, they will connect *proper sized* tube with male AN fittings. i've used them in AN-3 size in brake applications... the nut provides a compressive taper clamping on the sleeve. |
Britain Smith |
Jun 24 2005, 05:25 PM
You have the flare the tubing with those. You use them in conjuction with the tube nuts.
-Britain (IMG:http://www.britainsmith.com/Porsche/912Project/Assembly/images/179_0012_JPG.jpg) (IMG:http://www.britainsmith.com/Porsche/912Project/Assembly/images/179_0013_JPG.jpg) |
Lo-Fi Version | Time is now: 11th June 2024 - 08:32 PM |
