ClayPerrine
Jun 24 2005, 11:45 AM
What was this thread SUPPOSED to be?
Mueller
Jun 24 2005, 12:03 PM
bummer, I wanted to know how well these work, I was thinking of trying them out............
Britain Smith
Jun 24 2005, 12:09 PM
They have a max pressure of something like 25psi or something. I looked into them and determined that they were not acceptable for high fuel pressure. I ended up borrowing a 37degree flaring tool and doing it correctly.
-Britain
DougC
Jun 24 2005, 12:24 PM
Sorry guys, the server (or something) was acting up when I originally tried to post the message.."Fatal Error, timeout" I think it said. But, basically I was wondering how well they worked because I don't have a flaring tool and wanted to try them. BUT, I'll be using CIS in a 2.7 and they run lots of pressure so I guess this may not be for me..
Doug C
ArtechnikA
Jun 24 2005, 04:17 PM
have you thought of
these ?when used with the tube nut, they will connect *proper sized* tube with male AN fittings.
i've used them in AN-3 size in brake applications...
the nut provides a compressive taper clamping on the sleeve.
Britain Smith
Jun 24 2005, 05:25 PM
You have the flare the tubing with those. You use them in conjuction with the tube nuts.
-Britain
