| mepstein |
Apr 29 2019, 02:18 PM
914-6 GT in waiting ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 20,924 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region
Does a good job cleaning up the parts but leaves a residue. I bought some kitty liter and home that will work to clean it up and give it a final polish. It’s loud but I found a place in back of the building so it’s not so annoying.
| burton73 |
Apr 29 2019, 03:00 PM
Senior member, and old dude ![]() ![]() ![]() ![]() Group: Members Posts: 4,089 Joined: 2-January 07 From: Los Angeles Member No.: 7,414 Region Association: Southern California
I got the same one and tried on a set of lugs. It left some crap on them. I have been to the factories that make this stuff. They use polyester casting resin and fill it with the grit and pour it in rubber molds of a pyramid shape and then pop them out but the millions. I think it leaves resin on the pieces. As Acetone should clean that off as it eats/thins resin
Bob B |
| 914Sixer |
Apr 29 2019, 03:02 PM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 9,583 Joined: 17-January 05 From: San Angelo Texas Member No.: 3,457 Region Association: Southwest Region
Never had good luck with them. Maybe just me.
| bdstone914 |
Apr 29 2019, 04:52 PM
bdstone914 ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,397 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 |
Does a good job cleaning up the parts but leaves a residue. I bought some kitty liter and home that will work to clean it up and give it a final polish. It’s loud but I found a place in back of the building so it’s not so annoying. Never had much luck either with vibrator tumblers. Ok for things shaped like rocks but will not get to recessed surfaces. An ultra sonic works great on latches like you have in there. Just got a cheap HF one and I have cleaned the worse parts like CVs. Wish I got one years ago. Great on tools with dirt packed in grooves like pliers. |
| Beach914 |
Apr 29 2019, 04:59 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,014 Joined: 28-March 10 From: Aliso Viejo Member No.: 11,519 Region Association: Southern California
My experience in the stamping industry is that it is used with soapy water. Parts have to be rinsed and then dried or continued into a plating process......
Can't say I ever seen it done dry. |
| Mueller |
Apr 29 2019, 05:25 PM
914 Freak! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 17,155 Joined: 4-January 03 From: Antioch, CA Member No.: 87 Region Association: None
Ditto on the soapy water.
| burton73 |
Apr 29 2019, 05:30 PM
| bbrock |
Apr 29 2019, 06:17 PM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,269 Joined: 17-February 17 From: Montana Member No.: 20,845 Region Association: Rocky Mountains
Okay, I admit I was expecting to find something much more risque when I opened this thread but...
I've had pretty good luck with mine. Kitty litter didn't work for me because it pounded to dust too quickly. Might have gotten the wrong stuff. The pyramid resin chips have worked the best and like others have said, works better with some sort of solvent. I had the best luck with Pine-sol in the resin chips. Also as others have said, there are limits on how far it gets into recesses etc. For fine polish, filling the tumbler with walnut shells worked pretty well. My HF ultrasonic cleaner worked great for the little while it worked before it crapped out. The electronics panel is right on the front where it gets dripped on every time you remove the lid and is not sealed well. Take extra steps if you don't want yours to die young like mine did. |
| bdstone914 |
Apr 29 2019, 06:30 PM
Okay, I admit I was expecting to find something much more risque when I opened this thread but... I've had pretty good luck with mine. Kitty litter didn't work for me because it pounded to dust too quickly. Might have gotten the wrong stuff. The pyramid resin chips have worked the best and like others have said, works better with some sort of solvent. I had the best luck with Pine-sol in the resin chips. Also as others have said, there are limits on how far it gets into recesses etc. For fine polish, filling the tumbler with walnut shells worked pretty well. My HF ultrasonic cleaner worked great for the little while it worked before it crapped out. The electronics panel is right on the front where it gets dripped on every time you remove the lid and is not sealed well. Take extra steps if you don't want yours to die young like mine did. @Epstein Can you post pics of the final results? @bbrock I gave up on my HF vibrator but did not try various media. I have gone thru three HF ultra Sonics for the same reason. The condensed water pours onto the electrical panel and it gives error codes and craos out. So I put them in the sun till the water in out of the display. Then exchange them under warranty. |
| mepstein |
Apr 29 2019, 07:21 PM
Here’s the parts after I rinsed off the kitty litter powder. No residue from the ceramic media. Left it smooth but dull. I’m guessing this will result in a dull finish if I zinc plate. @bbrock will walnut shells actually shine it up or am I chasing my tail.
Last year I bead blasted a 5 gallon bucket of hardware but left it in my garage so everything had a light coating of rust. I don’t have the patience to head blast again and I was hoping for a smoother finish than what results from blasting. Suggestions are appreciated. Attached thumbnail(s) |
| iankarr |
Apr 29 2019, 07:31 PM
The wrencher formerly known as Cuddy_K ![]() ![]() ![]() ![]() Group: Members Posts: 2,607 Joined: 22-May 15 From: Heber City, UT Member No.: 18,749 Region Association: Intermountain Region
Where do the C batteries go?
| 76-914 |
Apr 29 2019, 07:33 PM
Repeat Offender & Resident Subaru Antagonist ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 13,973 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California
I bought one of those. In fact I forgot that I bought one and bought another when on sale. (IMG:style_emoticons/default/av-943.gif) I gave one to my SiL who makes jewelry. Damned nice one off stuff. Anyway, she uses some SS shot for media. She said its expensive but damn the results looked nice. It also covered those little nooks and crannies well. You might look into this stuff for a nice finish. If you don't find it PM me and I'll get the info/link from her. (IMG:style_emoticons/default/beerchug.gif)
| Freezin 914 |
Apr 29 2019, 07:51 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 942 Joined: 27-July 14 From: Wisconsin Member No.: 17,687 Region Association: Upper MidWest
I am not as tech savvy as you guys, so don’t know how to post a link. But as for polishing items, I would search for a YouTube video by redline media shop, it is a video on restoring old hot wheels, the spectraflame type. He covers the media he uses, it is a mixture of walnut shell media, the stones you all refer to. Also mixes them with polishing stones, comet, borax etc. the car body’s come out nice and shiny. Maybe just check it out. May help get desired results you are looking for. (IMG:style_emoticons/default/stirthepot.gif)
| mepstein |
Apr 29 2019, 07:53 PM
I bought one of those. In fact I forgot that I bought one and bought another when on sale. (IMG:style_emoticons/default/av-943.gif) I gave one to my SiL who makes jewelry. Damned nice one off stuff. Anyway, she uses some SS shot for media. She said its expensive but damn the results looked nice. It also covered those little nooks and crannies well. You might look into this stuff for a nice finish. If you don't find it PM me and I'll get the info/link from her. (IMG:style_emoticons/default/beerchug.gif) Looks like it's easy to find on amazon & ebay. I'll give it a try. |
| bbrock |
Apr 29 2019, 08:08 PM
Here’s the parts after I rinsed off the kitty litter powder. No residue from the ceramic media. Left it smooth but dull. I’m guessing this will result in a dull finish if I zinc plate. @bbrock will walnut shells actually shine it up or am I chasing my tail. Last year I bead blasted a 5 gallon bucket of hardware but left it in my garage so everything had a light coating of rust. I don’t have the patience to head blast again and I was hoping for a smoother finish than what results from blasting. Suggestions are appreciated. Quickest way to shine the big stuff like that is with a wire wheel. Should take less than a minute to polish off the latch. This was one of the earlier pieced I plated so not my best work, but not bad. I used walnut shell mostly on stuff too small to wire brush. Walnut might polish the larger stuff, but I'll bet it would take a long time. As was already said, there are some good Youtube vids of people trying all kinds of things with different results. There are some good tips on prepping for electroplating in this one: https://www.youtube.com/watch?v=hTupOgImpWo |
| mepstein |
May 3 2019, 08:58 PM
So the kitty litter was ok but not really and made sort of a mess. I took 76-914 advice and purchased steel shop off ebay (cheaper than amazon) 10lbs for $18 shipped. I didn't use stainless because I was using ferrous metal anyway. Stainless is good when you don't want to leave residue that can rust. So far the results look great. A couple bonuses with the steel shot; The tumbler runs much much quieter. It works quickly, I could see results in 15-20 minutes, not hours. It doesn't leave any mess. It last WAY longer than other media, like 1000x longer. The only downside is the steel shot is so much denser that 10lbs isn't enough to cover the pieces. I had to order another 10lb bag and wait until Tuesday for delivery.
Here's a pic of the first batch I sent to get plated. Attached thumbnail(s) |
| mepstein |
May 13 2019, 10:32 AM
Don’t send the rear latch receiver through.
| mepstein |
May 13 2019, 10:34 AM
First batch is done and I’m very happy with the results.
There is a time and labor investment involved. Attached thumbnail(s) |
| 76-914 |
May 13 2019, 10:56 AM
So the kitty litter was ok but not really and made sort of a mess. I took 76-914 advice and purchased steel shop off ebay (cheaper than amazon) 10lbs for $18 shipped. I didn't use stainless because I was using ferrous metal anyway. Stainless is good when you don't want to leave residue that can rust. So far the results look great. A couple bonuses with the steel shot; The tumbler runs much much quieter. It works quickly, I could see results in 15-20 minutes, not hours. It doesn't leave any mess. It last WAY longer than other media, like 1000x longer. The only downside is the steel shot is so much denser that 10lbs isn't enough to cover the pieces. I had to order another 10lb bag and wait until Tuesday for delivery. Here's a pic of the first batch I sent to get plated. I'll pass the compliment onto my sister in law. (IMG:style_emoticons/default/beerchug.gif) BTW, those look great! (IMG:style_emoticons/default/drooley.gif) |
| bbrock |
May 13 2019, 12:21 PM
First batch is done and I’m very happy with the results. There is a time and labor investment involved. Nice! (IMG:style_emoticons/default/drooley.gif) My stuff is at the same shop waiting for plating now. I did not send the rear trunk receiver thank goodness. |
Lo-Fi Version | Time is now: 6th October 2026 - 12:25 AM |
