Wire harness sleeve, Where to buy? |
shane |
Apr 30 2019, 06:45 AM
Member Group: Members Posts: 355 Joined: 12-February 13 Member No.: 15,518 Region Association: None |
I did a search and found nothing, What’s everyone using as a factory looking replacement? Wanted to use a sleeve or wrap. I know not factory but I don’t want to take my Harnesss apart to install factory correct sleeving. Thanks in advance (IMG:style_emoticons/default/beerchug.gif)
dr914@autoatlanta.com |
Apr 30 2019, 07:51 AM
914 Guru Group: Members Posts: 7,894 Joined: 3-January 07 From: atlanta georgia Member No.: 7,418 Region Association: None |
if you mean the covering for the metal bend holders on the body, we have them, also the cloth tape is available, and Whitesell makes the trombone that covers the harness where it goes through the front engine shelf.
I did a search and found nothing, What’s everyone using as a factory looking replacement? Wanted to use a sleeve or wrap. I know not factory but I don’t want to take my Harnesss apart to install factory correct sleeving. Thanks in advance (IMG:style_emoticons/default/beerchug.gif) |
Chi-town |
Apr 30 2019, 07:57 AM
Whitesell aka 914Rubber
bbrock |
Apr 30 2019, 08:14 AM
I'm assuming they are talking about the sleeving on the actual harness. I got some sleeving that is a match for the original from @IronHillRestorations . For parts of the harness I didn't want to take apart, I bought black shrink tubing from Digikey with a 3:1 shrink ratio so I could slide it over connectors etc. and shrink it down to snug fit on the wires. You have to look hard to see any difference from the original sleeve. In a few other places, I used oversized sleeving split lengthwise to wrap around the wire bundle and then tape with a spiral of 1/2" wide electrical tape. There were a few spots where the factory had done that on my harness anyway. (IMG:style_emoticons/default/beerchug.gif)
Mark Henry |
Apr 30 2019, 02:57 PM
Hockey tape.
sithot |
Apr 30 2019, 03:50 PM
Member Group: Members Posts: 446 Joined: 25-October 06 From: Virginia Member No.: 7,090 Region Association: None |
Hockey tape. (IMG:style_emoticons/default/agree.gif) And if you feel like being different.... https://www.amazon.com/Renfrew-Cloth-Hockey...ASIN=B015BRTOOY |
Lo-Fi Version | Time is now: 8th June 2024 - 07:52 AM |
