WTB: Triad Exhaust |
rbzymek |
May 1 2019, 08:45 AM
Member Group: Members Posts: 195 Joined: 5-April 19 From: Northville, MI Member No.: 23,013 Region Association: Upper MidWest |
Looking for a Traid exhaust to replace my Bursch system. I have factory heat exchangers on the car. Thanks in advance.
Ray |
Mikey914 |
May 1 2019, 09:28 AM
The rubber man Group: Members Posts: 12,678 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None |
If I recall correctly you have the 1.7 / 2.0 heat exchanger flanges. The 1.8 are more triangle shaped.
euro911 |
May 1 2019, 03:57 PM
Retired & living the dream. God help me if I wake up! Group: Members Posts: 8,851 Joined: 2-December 06 From: So.Cal. & No.AZ (USA) Member No.: 7,300 Region Association: Southern California |
Early 1.7L & 1.8L are pretty much identical ... 2.0L is different, mainly the up-sweep near the muffler flanges ...
...bit there's also a difference of the distance between the flanges ... |
rbzymek |
May 1 2019, 05:10 PM
Early 1.7L & 1.8L are pretty much identical ... 2.0L is different, mainly the up-sweep near the muffler flanges ... ...bit there's also a difference of the distance between the flanges ... The pictures are helpful. I think I have a 1.8 system. I have contacted Dave so a new Triad may be the way to go. Yes the trans needs a rebuild as well. I also have most of the parts to switch back to L-Jet so it goes on the jack stands soon. Ray |
ndfrigi |
May 1 2019, 05:26 PM
Advanced Member Group: Members Posts: 2,933 Joined: 21-August 11 From: Orange County Member No.: 13,474 Region Association: Southern California |
Early 1.7L & 1.8L are pretty much identical ... 2.0L is different, mainly the up-sweep near the muffler flanges ... ...bit there's also a difference of the distance between the flanges ... The pictures are helpful. I think I have a 1.8 system. I have contacted Dave so a new Triad may be the way to go. Yes the trans needs a rebuild as well. I also have most of the parts to switch back to L-Jet so it goes on the jack stands soon. Ray you have a 2.0 HE |
rbzymek |
May 29 2019, 11:36 AM
Early 1.7L & 1.8L are pretty much identical ... 2.0L is different, mainly the up-sweep near the muffler flanges ... ...bit there's also a difference of the distance between the flanges ... The pictures are helpful. I think I have a 1.8 system. I have contacted Dave so a new Triad may be the way to go. Yes the trans needs a rebuild as well. I also have most of the parts to switch back to L-Jet so it goes on the jack stands soon. Ray you have a 2.0 HE Cancel request. I purchased a new exhaust from Dave. |
Lo-Fi Version | Time is now: 12th June 2024 - 08:18 AM |
