Another turboed 914, something a little different ? |
Bills914-4 |
May 4 2019, 04:37 PM
Member Group: Members Posts: 310 Joined: 1-March 08 From: suburbs of Miami FL. Member No.: 8,762 Region Association: South East States |
Hello , I've been wanting to build a turbo system for my 914 , so I bought a few parts
recently & thought I'd give it a try , this system is temporarily on my 2.8-4 twinplug motor for now . I know we like picture's so here's a few (IMG:style_emoticons/default/smile.gif) , thanks for looking Bill D. I'm running low boost 7psi max on this motor (2.8 twinplug 10.7 cr ) , I'm in process of building a 2.5 to run 14 + psi of boost (IMG:style_emoticons/default/smile.gif) , http://www.914world.com/bbs2/index.php?act...=0#entry2617707 bought a few bits & pieces & did some fab work little by little thats little bullet muffler |
Retroracer |
May 4 2019, 05:07 PM
Senior Member Group: Members Posts: 616 Joined: 7-July 13 From: Bend OR Member No.: 16,100 Region Association: Pacific Northwest |
That looks like fun! No intercooler and 7PSI should be manageable - but with the placement you have, there's room to put an intercooler in the upper part of the trunk area for when you make the motor swap to get to 15+ PSI. Some venting or interesting ducting could be crafted on the trunk, which looking at your fabrication skills on what you've done should be no problem!
- Tony |
914forme |
May 4 2019, 05:13 PM
I will tell you, run a bead or flare your pipe, at the low boast you are running they might hold. I would blow them off my TDI build. Changed to double clamps T-clamps and 6 inches of coverage, still would blow off. Beaded the ends of the tubes, no more blow off.
(IMG:style_emoticons/default/poke.gif) I was running 45 psi of boost (IMG:style_emoticons/default/shades.gif) Just do it the right way, and not worry about it. Other than that enjoy the fun, if you drop E-85 you should be able to run the 2.8 boasted with out issues, might even get it to 11. (IMG:style_emoticons/default/aktion035.gif) |
Dave_Darling |
May 4 2019, 07:42 PM
I'm surprised nobody has said it yet:
"Everybody knows you can't turbocharge a 914!" (Especially the people who have successfully done it and loved theirs for years.) --DD |
Stiffmeister |
May 5 2019, 03:20 AM
Newbie Group: Members Posts: 17 Joined: 11-January 15 From: Sweden Member No.: 18,315 Region Association: None |
Me like (IMG:style_emoticons/default/driving.gif)
Andyrew |
May 5 2019, 05:01 AM
Great looking system! What turbo size did you go with
Watch your water injection carefully, you'll need to make sure there is adequate dispersion of the water droplets or youll find yourself with hot cylinders. Individual nozzles per cyl would be ideal. |
ottox914 |
May 5 2019, 08:05 AM
The glory that once was. Group: Members Posts: 1,302 Joined: 15-December 03 From: Mahtomedi, MN Member No.: 1,438 Region Association: Upper MidWest |
Check my links below for my turbo adventures. Some thoughts on water injection. Spraying just after the turbo outlet will provide maximum charge air cooling. Injecting closer to the throttle bodies will provide more of the octane boost. Straight water can be used with good results as a cooling mist, water/meth is better for an octane boost. In my perfect world I would port inject at the intake runners, and spray another mist just after the turbo. Best of both worlds.
While I didn't use WI on my 914 turbo, I did consider it. I wanted to try my idea for a central mounted air to air, and it worked amazingly well. I still have the IC if you want to throw me some bucks and plumb it into your system. I used WI on a turbo focus I built, which I later converted to an air/water system. Your car on E85 with WI should be good at 7psi, and probably more. Your car on the dyno will tell you how much is to much with that set up, and when you need to upgrade you IC system. |
tazz9924 |
May 5 2019, 11:52 AM
Senior Member Group: Members Posts: 703 Joined: 31-May 15 From: Mooresville NC Member No.: 18,779 Region Association: None |
im not sure that air intake is getting enough air in its current placement. What it is getting is gonna be hot, so id suggest moving it and u might get some more power too. It will also help with the detonation problems an intercoolerless system can be subject to.
ottox914 |
May 5 2019, 08:50 PM
Look for some build threads from member "iamchappy" He has gone down the same path you have started on.
get off my lawn |
May 6 2019, 03:48 PM
Member Group: Members Posts: 168 Joined: 18-August 11 From: west coast Member No.: 13,462 Region Association: None |
I'm surprised nobody has said it yet: "Everybody knows you can't turbocharge a 914!" (Especially the people who have successfully done it and loved theirs for years.) --DD I knew you wouldn't let me down. Attached image(s) |
Bills914-4 |
May 7 2019, 03:42 PM
Thanks Guys for the words (IMG:style_emoticons/default/smile.gif) , yeah I'm planning on IC in the future might be sooner
then I planned , Tuning will tell , still in beginning stages of tuning , I'm still learning megasquirt ( tunerstudio ) need to learn programmable water meth injection it's somewhat similar to tunerstudio , it works with rpm & map/boost sensor , at the moment I'm running one injector nozzle on each side in the elbow above the TB hat they are (#3) 175 ML/MIN , I have more clamps to install double per joint ,I'm going to try that for now , some of the tubes have a bead some of the ones I trimmed don't , besides if and when I add IC this plumbing will change , intake air temp is a concern , I've seen it get hot in the trunk , I've got some idea's to fix or change that , in the meantime I'm going to monitor iat while I'm trying to tune it , Thanks Bill D. O-yea this thread would not have been complete without that phrase (IMG:style_emoticons/default/biggrin.gif) , "Everybody knows you can't turbocharge a 914!" http://sohiperformance.com/i-7470031.aspx?...AiABEgIByPD_BwE Snow Performance water-methanol injection with OEM level fuel system control for exact amounts of water-methanol to be delivered at any RPM range of the vehicle. The Stage 4 Boost Coolerâ„¢ utilizes engine RPM/Boost PSI to create a 2D fully adjustable water-methanol tune. Unlike any other system on the market the Stage 4 can give more or less water-methanol at any specific engine load state similar to a stand alone ECU. Using Snow Performance Platinum Tuning Software (free) the tuner can monitor, adjust water-meth delivery, data log/save files, and save/send completed water-methanol tunes to remote customers using a computer while on the dyno. Comes complete with Bosch MAP sensor, custom billet mount, USB cord, terminated wiring connections, LED alert system |
Lo-Fi Version | Time is now: 10th June 2024 - 02:29 PM |
