> Exhaust to head gasket removal, Help removeing the copper exhaust gasket
Krohn
post May 10 2019, 08:32 PM
Is there a magic trick or a special tool that's needed to remove the copper gasket from the head where the exhaust bolts?
I'm in the processing of cleaning (and more cleaning and more cleaning and more cleaning... ) from 50 years of oil leaks and in the process of partial disassembly for some push rod tube seal replacement, but after removing the head exchangers, I haven't found a reasonable way of removing the copper gaskets from the head. Any helpful experience or out there?
Replies(1 - 6)
Mark Henry
post May 10 2019, 09:09 PM
that's what I do!
Old flat screwdriver, heat the tip cherry red and bend the tip 90 degrees.
Hook it on the edge of the gasket and pull down.
I have several pry and install tools made from old screwdrivers like this.
Superhawk996
post May 11 2019, 07:52 AM
I have a small pick shaped tool with a slight bend in the tip. Just use it to hook underneath the copper gasket. It works every time.
I like Mark's idea too. (IMG:style_emoticons/default/beerchug.gif) Always up for making a new special tool from those I already have on hand!
porschetub
post May 11 2019, 03:50 PM
Be very careful removing these,if you damage the machined surface on the head you are basically screwed,they can be hard to get out with the motor installed.
I usually file the surfaces on heatexchangers and check for basic flatness with a straight edge,this method has cured exhaust leaks on 2 of my motors.
The studs require close inspection also as the end threads rust away,I use a self locking nuts I got from Pelican years ago,they are made for exhausts and from memory they were a early BMW part,so good I used them on my 2.2T six motor to really good result.
Good luck.
Rand
post May 11 2019, 03:55 PM
Cross Member
(IMG:http://www.914world.com/bbs2/uploads_offsite/shop.harborfreight.com-3573-1557611814.1.jpg)
https://www.harborfreight.com/mini-pick-and...-set-63697.html
The idea is to hook and pull on the ring only. As was said, don't scarf the sealing surface.
r_towle
post May 12 2019, 08:37 AM
Custom Member
QUOTE(Mark Henry @ May 10 2019, 10:09 PM) *
several is because you lose them, and have to make another one.
I know....
Rich
Superhawk996
post May 12 2019, 08:45 AM
QUOTE(r_towle @ May 12 2019, 10:37 AM) *
I know....
Rich
(IMG:style_emoticons/default/av-943.gif) So true. I have multiples of tools just so when I misplace one, I don't have to stop working to look for it. They always turn up in some strange place when I'm doing clean up!
- Lo-Fi Version Time is now: 15th April 2026 - 02:09 AM
