Rebuilt calipers, Help needed |
Fatarse |
May 14 2019, 01:56 PM
Newbie Group: Members Posts: 12 Joined: 25-June 16 From: Scottsdale, AZ Member No.: 20,143 Region Association: None |
Right rear brake looks to have locked up after a recent caliper rebuild (less than 50 miles). I followed a pelican article and loosened the hex by going clockwise...wouldn’t twist counter. Brake pads look like they are glued to the rotor though...if anyone is in Phoenix area, there’s a six pack for anyone wanting to come to the garage and help me get the car on the road.
Attached thumbnail(s) |
Chi-town |
May 14 2019, 04:07 PM
Senior Member Group: Members Posts: 850 Joined: 31-August 18 From: Disneyland Member No.: 22,446 Region Association: Southern California |
Did you set the gap originally?
Are the parking brake cables moving freely and not keeping tension on the caliper? Is the brake pedal returning all the way (can you pull up on it?) |
Fatarse |
May 14 2019, 04:50 PM
Thanks Chi-Town. Autobahn Garage rebuilt the calipers, so I did not set the gap. Can’t really tell about the brake cables, but the brake pedal is all the way up. I am trying to get the piston to return to the housing, but don’t know how far to turn the adjuster clockwise. Pads looked glued to the rotors at this point and rotor will not turn by hand.
Chi-town |
May 14 2019, 05:01 PM
Ok, there's an adjuster on both pistons in each caliper. Removed both caps (need to go through the hole in the trailing arm for the inside one) and unscrew the adjuster till you see the pad start to move back towards the caliper. Some times you have to push a little on the pad while turning the adjuster.
Once you get them backed off then you can set the correct gap. |
Fatarse |
May 14 2019, 05:23 PM
Does the caliper need to be removed in order to loosen the inner adjuster?
Chi-town |
May 14 2019, 07:20 PM
No, you'll need an Allen key socket and a 10-12" extension
Fatarse |
May 14 2019, 09:24 PM
Local shop thinks it’s an issue with the parking brake. Anyone know someone in Phoenix that can work on this with me?
rjames |
May 14 2019, 10:19 PM
I'm made of metal Group: Members Posts: 3,955 Joined: 24-July 05 From: Shoreline, WA Member No.: 4,467 Region Association: Pacific Northwest |
Local shop thinks it’s an issue with the parking brake. Anyone know someone in Phoenix that can work on this with me? Should be obvious if the parking brake is on. You can see the cable where it attaches to the caliper. Is it slack or taut? Once you see where it connects you’ll be able to tell how to disconnect or loosen the cable. |
Chi-town |
May 14 2019, 10:27 PM
Simply pull the little pin out at the connection from the cable to the caliper.
If the cable is stuck the caliper will release when the pin is pulled |
Fatarse |
May 16 2019, 06:29 PM
This sounds incredibly simple, but any pictures or diagrams of what pin I’m supposed to pull?
mepstein |
May 16 2019, 07:10 PM
914-6 GT in waiting Group: Members Posts: 19,316 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
This sounds incredibly simple, but any pictures or diagrams of what pin I’m supposed to pull? The pin that connects the end of the ebrale cable to the ebrake lever arm on the caliper. It has a tiny c-clip on the end. On the east coast they are always corroded over so I get them cherry red with map gas and then work it loose. |
Fatarse |
May 18 2019, 01:28 PM
Trying to take the pads out. Tried using a screwdriver, but not wiggling at all. Any suggestions?
Fatarse |
May 18 2019, 04:20 PM
Got one pad out, but no luck on the inner. Rotor still won’t rotate...any thoughts?
Fatarse |
May 18 2019, 04:32 PM
After tapping the arm I was able to get the rotor to rotate and remove the inner brake pad. Everything looks clean.
rjames |
May 18 2019, 11:37 PM
davep |
May 20 2019, 11:18 AM
914 Historian Group: Benefactors Posts: 5,154 Joined: 13-October 03 From: Burford, ON, N0E 1A0 Member No.: 1,244 Region Association: Canada |
I agree with Robert. If the pads do not slip in and out of the pad cavity easily, then essentially the pads are seized. The pad cavity needs to be cleaned and coated to prevent corrosion and this sort of problem. Just putting new seals in the piston bores is NOT a rebuild. If the external surfaces of the caliper have not been cleaned, then the internal surfaces are probably at least as bad. That will just lead to continuing problems.
PMB does a full restoration job including new plating. That's a ticket to ride. |
Fatarse |
May 20 2019, 09:03 PM
Thanks. Car is now at Exotic Motorwerks in Scottsdale. Hope they can give me an honest assessment of condition and what needs to be done to get it on the road.
rjames |
May 21 2019, 09:49 AM
Thanks. Car is now at Exotic Motorwerks in Scottsdale. Hope they can give me an honest assessment of condition and what needs to be done to get it on the road. Decent calipers. PMB Performance https://www.pmbperformance.com/914-brakes.html |
Lo-Fi Version | Time is now: 10th June 2024 - 07:10 AM |
