Where does this white wire go? |
John90290 |
May 18 2019, 12:13 PM
Member Group: Members Posts: 93 Joined: 4-March 18 From: Ventura, CA Member No.: 21,937 Region Association: None |
1975 1.8 FI. Got engine back in and most things commented bit don’t know what this white wire connects to ?
Attached thumbnail(s) |
dlee6204 |
May 18 2019, 12:46 PM
Howdy Group: Members Posts: 2,162 Joined: 30-April 06 From: Burnsville, NC Member No.: 5,956 |
That wire should be connected to your CHT sensor. The other wire connector that you currently have your cht plugged into with the green wire... that green wire I think goes to your oil temperature sensor IIRC.
windforfun |
May 18 2019, 01:15 PM
Senior Member Group: Members Posts: 1,833 Joined: 17-December 07 From: Blackhawk, CA Member No.: 8,476 Region Association: None |
What does CHT mean?
914werke |
May 18 2019, 01:38 PM
"I got blisters on me fingers" Group: Members Posts: 10,124 Joined: 22-March 03 From: USofA Member No.: 453 Region Association: Pacific Northwest |
cylinder head temp
dr914@autoatlanta.com |
May 18 2019, 03:39 PM
914 Guru Group: Members Posts: 7,893 Joined: 3-January 07 From: atlanta georgia Member No.: 7,418 Region Association: None |
Bleyseng |
May 18 2019, 07:29 PM
Aircooled Baby! Group: Members Posts: 13,035 Joined: 27-December 02 From: Seattle, Washington (for now) Member No.: 24 Region Association: Pacific Northwest |
How rich did it run? (IMG:style_emoticons/default/piratenanner.gif)
SirAndy |
May 19 2019, 09:16 AM
Resident German Group: Admin Posts: 41,675 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
That wire should be connected to your CHT sensor. The other wire connector that you currently have your cht plugged into with the green wire... that green wire I think goes to your oil temperature sensor IIRC. (IMG:style_emoticons/default/agree.gif) Green/Black is oil temp, there should be a matching one coming out of the main harness on the fire wall that plugs into that instead of the CHT. (IMG:style_emoticons/default/sunglasses.gif) |
John90290 |
May 19 2019, 10:20 AM
That wire should be connected to your CHT sensor. The other wire connector that you currently have your cht plugged into with the green wire... that green wire I think goes to your oil temperature sensor IIRC. (IMG:style_emoticons/default/agree.gif) Green/Black is oil temp, there should be a matching one coming out of the main harness on the fire wall that plugs into that instead of the CHT. (IMG:style_emoticons/default/sunglasses.gif) I got the green red out of harness to oil pressure switch. White now to cht. This leaves the green black unattached. That’s the one I had connected to the cht. In the original picture. Attached thumbnail(s) |
SirAndy |
May 19 2019, 10:31 AM
That wire should be connected to your CHT sensor. The other wire connector that you currently have your cht plugged into with the green wire... that green wire I think goes to your oil temperature sensor IIRC. (IMG:style_emoticons/default/agree.gif) Green/Black is oil temp, there should be a matching one coming out of the main harness on the fire wall that plugs into that instead of the CHT. I got the green red out of harness to oil pressure switch. White now to cht. This leaves the green black unattached. That’s the one I had connected to the cht. In the original picture. *main* harness, not engine harness. There should be a green/black coming out of the main harness near the hell hole. There should be a couple of wires that split to the passenger side from the main snorkel coming up in the center of the firewall. (IMG:style_emoticons/default/idea.gif) |
John90290 |
May 19 2019, 11:19 AM
The green black is out of the hell hole area. Don’t know where it goes?
John90290 |
May 19 2019, 11:20 AM
Dave_Darling |
May 19 2019, 11:50 AM
It goes under the car. On cars that have an oil temperature gauge, there should be a wire across the front of the motor on the underside of the engine tin, terminating in a connector under that area. The wire pictured there goes down through a hole in the engine shelf--or possibly that hole in the engine tin that is covered by the black plug in your pic?--and connects to it.
--DD |
John90290 |
May 19 2019, 11:54 AM
It goes under the car. On cars that have an oil temperature gauge, there should be a wire across the front of the motor on the underside of the engine tin, terminating in a connector under that area. The wire pictured there goes down through a hole in the engine shelf--or possibly that hole in the engine tin that is covered by the black plug in your pic?--and connects to it. --DD awesomeness!!! You guys are great! Now I have to get the fuel pump working. That’s another post (IMG:style_emoticons/default/sad.gif) |
Lo-Fi Version | Time is now: 6th June 2024 - 07:19 AM |
