1.7 liter Stock rebuild |
pgollender |
May 25 2019, 04:14 PM
Member Group: Members Posts: 193 Joined: 5-July 11 From: Sacramento Member No.: 13,281 Region Association: Northern California |
I had too many 1.7L parts to justify "throwing them away" or parting out so I decided to go the other way and do a complete rebuild and assembly of a spare "W" series block. This was my second rebuild 1.7L and infinitely more fun than the first which is in my '70. It will be plug and play and play ready for a nice deserving owner that doesn't want to do all the work. Besides the core part of the rebuild, I tackled some of the common issues that we encounter AFTER a rebuild that leaves us with more problems that require trouble shooting rather than enjoying our new motors. Some amenities include reconditioned fuel injectors by RC Fuel Injection, rebuilt MPS by yours truly, electric fuel pump, completely re-worked, reconditioned engine harness and matching ECU. Will post complete rebuild spex in classified when I'm done next month.
pgollender |
May 25 2019, 04:17 PM
pgollender |
May 25 2019, 04:23 PM
Literati914 |
May 25 2019, 06:45 PM
Senior Member Group: Members Posts: 1,473 Joined: 16-November 06 From: Dallas, TX Member No.: 7,222 Region Association: Southwest Region |
That looks clean, well done! What paint did you use on that fan shroud?
thelogo |
May 25 2019, 08:44 PM
Senior Member Group: Retired Members Posts: 1,510 Joined: 6-April 10 Member No.: 11,572 Region Association: None |
I was just gonna say i like the clean look and its spotless (IMG:style_emoticons/default/pray.gif) |
pgollender |
May 26 2019, 09:05 AM
That looks clean, well done! What paint did you use on that fan shroud? I used a VHT rattle can high temp paint, called " Cast Aluminum" and baked it at 275 for two hours. It came out way better than I thought it would. "1971 Volvo 1800E, Grigio Medio" Literati, I would love to see pictures of your 1800. |
Superhawk996 |
May 26 2019, 01:07 PM
914 Guru Group: Members Posts: 5,876 Joined: 25-August 18 From: Woods of N. Idaho Member No.: 22,428 Region Association: Galt's Gulch |
Beautiful work. Always love to see someone keeping them stock. Well, stock never looked that nice but you know what I mean. (IMG:style_emoticons/default/shades.gif) |
Spoke |
May 26 2019, 01:19 PM
Jerry Group: Members Posts: 6,989 Joined: 29-October 04 From: Allentown, PA Member No.: 3,031 Region Association: None |
Looks great! Too bad the engine will be put in a car and get dirty.
BTW, if you painted the fan shroud, the mounting surfaces to the engine should be clear of paint since those 4 points are the main ground return for the alternator. Chances are you'll be ok if you didn't powder coat the shroud. Zach had a ton of alternator issues before realizing that powder coating the shroud increases the ground resistance to the alternator. |
Literati914 |
May 26 2019, 09:39 PM
I used a VHT rattle can high temp paint, called " Cast Aluminum" and baked it at 275 for two hours. It came out way better than I thought it would. "1971 Volvo 1800E, Grigio Medio" Literati, I would love to see pictures of your 1800. Thanks for the paint info, I'll be buying some. I had tons of pics of my volvo 1800E on my dead old phone and my dead old dell laptop...here's a couple crappy shots I do have tho: (IMG:http://www.914world.com/bbs2/uploads_offsite/i65.tinypic.com-7222-1558928376.1.jpg) |
Literati914 |
May 26 2019, 09:42 PM
It's not quite finished yet:
(IMG:http://www.914world.com/bbs2/uploads_offsite/i68.tinypic.com-7222-1558928522.1.jpg)[b] |
pgollender |
May 27 2019, 06:10 AM
Looks great! Too bad the engine will be put in a car and get dirty. BTW, if you painted the fan shroud, the mounting surfaces to the engine should be clear of paint since those 4 points are the main ground return for the alternator. Chances are you'll be ok if you didn't powder coat the shroud. Zach had a ton of alternator issues before realizing that powder coating the shroud increases the ground resistance to the alternator. Good to know, I can remove the paint at those places before final assembly. This is what's great about this forum. Always someone to help you out on what you've over-looked. |
pgollender |
May 27 2019, 06:19 AM
That is a beautiful car. It runs the same or similar Bosch D-jet set up as the 914's doesn't it ? I am surprised I don't see these mentioned in our group. It seems to be a forgotten little gem just like our 914's. Let me know if you know of someone wanting to sell a project one. I always loved that car since Roger Moore drove it in "The Saint ". |
Literati914 |
May 27 2019, 01:21 PM
That is a beautiful car. It runs the same or similar Bosch D-jet set up as the 914's doesn't it ? I am surprised I don't see these mentioned in our group. It seems to be a forgotten little gem just like our 914's. Let me know if you know of someone wanting to sell a project one. I always loved that car since Roger Moore drove it in "The Saint ". Thanks - Yep, it's the same D-jet system.. I haven't cross referenced the numbers yet (my cars are in off site storage atm), but Id bet the d-jet pieces interchange in some instances. Mines got the hi compression B20E engine. These are indeed forgotten gems, and relatively affordable from a project perspective - good parts availablity too. Getting hard to come by now..I'll keep my eye peeled for ya tho. |
Lo-Fi Version | Time is now: 2nd June 2024 - 12:22 AM |
