Where does this bolt to on the door? |
Steve |
May 26 2019, 09:00 PM
914 Guru Group: Members Posts: 5,606 Joined: 14-June 03 From: Orange County, CA Member No.: 822 Region Association: Southern California |
Any idea where #6 bolts to? This piece just slides into the rubber and hangs there? Is this some anti theft thing?
914 Ranch |
May 27 2019, 12:07 AM
Team Sharp where the 914 grow wings Group: Members Posts: 1,411 Joined: 29-January 16 From: TheNorth Shore Retreat. Deland Member No.: 19,611 Region Association: South East States |
Damn Steve, wish I could help but Carerror has no side windows and Nice 914 has early windows. but I believe that there is a nut welded in there somewhere. Isn't that upright adjustable for and aft on the bottom?
914 Ranch |
Steve |
May 27 2019, 07:23 AM
#7 bolts to the bottom and moves fore and aft. #6 just floats in mid air with nothing to bolt to.
Good to hear from you though!! Let us know when your back in this area for a visit. |
KevinW |
May 27 2019, 07:30 AM
Newbie Group: Members Posts: 42 Joined: 25-May 15 From: Winona, Minnesota Member No.: 18,761 Region Association: Upper MidWest |
There are actually two # 6 bolts. There are two holes in the door for them. One bolt goes in the tab the other in the triangle piece. The one hole is covered up in the picture. It is behind the vent window channel.
smveril |
May 27 2019, 01:58 PM
Mikey Group: Members Posts: 50 Joined: 6-December 04 From: Cincinnati, OH Member No.: 3,232 Region Association: Upper MidWest |
I was working on new seals for the triangular window today. The factory seals on the window have a pocket on the bottom of the seal and 6 holds a tab that goes into that pocket.
Steve |
May 27 2019, 07:11 PM
Bizarre but I have a spare door and it has the pocket for that #6 bolt and bracket.
The used doors I ended up using have the late model braces and late model gear regulator window winders, but it’s missing the metal that #6 bolt and brace bolts too. |
Mikey914 |
May 28 2019, 01:39 PM
The rubber man Group: Members Posts: 12,677 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None |
The metal was on the earlier cars most get removed when the new rubber goes in as it's just another hole that water can get into the door. It's also not necessary so if you can't find one no problem (IMG:style_emoticons/default/biggrin.gif)
I think it was over engineered and they realized there is no way the window rubber is going anywhere once it's in. |
Lo-Fi Version | Time is now: 1st June 2024 - 03:23 AM |
