Problem found whats the solution, Slow cranking when clutch is not engag |
736conver |
Jun 25 2005, 12:17 PM
Advanced Member Group: Members Posts: 2,117 Joined: 25-May 03 From: SE Wisconsin Member No.: 736 Region Association: None |
Ok some of you may remember I had a problem with slow starting of the car. I knew t was friction related of some sort. It always went away once the clutch pedal was pushed in. Thought maybe the trans was bad. It turns out the throw out arm is rubbing against the pressure plate. Cut a little groove too. Has anybody seen this before. And what is going on.
Attached image(s) |
Cap'n Krusty |
Jun 25 2005, 12:33 PM
Is the arm bent? Is the pressure plate the correct part for the application? Has the ball cup been shimmed? Has the pivot pin been shimmed too far? Maximum of 2 washers. The Cap'n
736conver |
Jun 25 2005, 12:37 PM
Capn
thanks for the reply arm doesnt look bent. No shims under the pivot ball. I had taken those out already. No shims for the ball cup its new by the way And the plate for this is 90111600101 or at least thats what the invoice says. Maybe its the wrong part in the right box. |
aircooledboy |
Jun 25 2005, 03:31 PM
Sweet Pea's 1st ride in daddy's "vroom -vroom" Group: Members Posts: 1,672 Joined: 4-February 04 From: Rockford, IL Member No.: 1,629 Region Association: Upper MidWest |
Brian, my V8 did the exact same thing. I ended up grinding a small relief groove in the arm to accomodate the p plate. Never did figure out why. My clutch was a KEP set up for the V8, and they told me sometimes you gotta bend the arm to clear the plate. (IMG:http://www.914world.com/bbs2/html/emoticons/confused24.gif) I decided the groove was easier than bending the arm just right.
bd1308 |
Jun 25 2005, 04:55 PM
Sir Post-a-lot Group: Members Posts: 8,020 Joined: 24-January 05 From: Louisville,KY Member No.: 3,501 |
my car started doing that too. When i did my engine swap. Um it's at the porsche mechanic now. He was impressed I got it to work at all.
Lo-Fi Version | Time is now: 29th May 2024 - 05:04 AM |
