Rear Coil Spring Question |
LCOX |
May 28 2019, 02:20 PM
Member Group: Members Posts: 93 Joined: 19-December 09 From: Pinnacle Member No.: 11,148 Region Association: None |
Anyone know how to determine the "spring rate" on rear suspension coil springs.
-The ones that I just took off my car appear to be the stock ones and I've heard are either 90 or 100lb springs. -The aftermarket ones I have here feel stiffer to push down. They are painted yellow and I don't see any markings on them. They are also several inches shorter than the stock ones that came off the car. -Any way of know what pound springs these yellow ones are? |
Mark Henry |
May 28 2019, 02:51 PM
roblav1 |
May 28 2019, 03:45 PM
Senior Member Group: Members Posts: 528 Joined: 18-September 12 From: KY Member No.: 14,943 Region Association: MidAtlantic Region |
I've used a 400 lb digital postal scale in a drill press. Weigh the spring first!
dr914@autoatlanta.com |
May 28 2019, 03:52 PM
914 Guru Group: Members Posts: 7,887 Joined: 3-January 07 From: atlanta georgia Member No.: 7,418 Region Association: None |
the old yellow ones were made by pacesetter and were rated at 120 lbs
Anyone know how to determine the "spring rate" on rear suspension coil springs. -The ones that I just took off my car appear to be the stock ones and I've heard are either 90 or 100lb springs. -The aftermarket ones I have here feel stiffer to push down. They are painted yellow and I don't see any markings on them. They are also several inches shorter than the stock ones that came off the car. -Any way of know what pound springs these yellow ones are? |
Dave_Darling |
May 28 2019, 09:00 PM
The original stock springs were in the 50-65 lb/in range.
You can measure the spring rate; it is pounds of force divided by inches of compression. Put weight on it, measure how much shorter it gets. --DD |
tomeric914 |
May 29 2019, 12:01 PM
One Lap of America in a 914! Group: Members Posts: 1,259 Joined: 25-May 08 From: Syracuse, NY Member No.: 9,101 Region Association: North East States |
You can measure the spring rate; it is pounds of force divided by inches of compression. Put weight on it, measure how much shorter it gets. (IMG:style_emoticons/default/agree.gif) Also take a look at the link in my signature on how to put together your own spring combo that is fully adjustable. |
Lo-Fi Version | Time is now: 3rd June 2024 - 10:36 AM |
