76-914 |
Repeat Offender & Resident Subaru Antagonist ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 13,738 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California ![]() ![]() |
I'd like to get some good Go Pro footage of the upcoming WCR drive and require some input from those in the know. I bought the Go Pro white last summer and have only used it a couple of times. So I ask, where are the optimum mounting locations. I'd like to get some engine noise so where would you mount it? It came with lots of mounts; eg suction cup and stick on hard mount tabs. Do you trust your camera hanging on the outside. What about wind noise? Anyway around that other than dubbing in music? There won't be another chance to record 914's in masse during my lifetime so I want to get it right! TIA, Kent
mepstein |
914-6 GT in waiting ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 19,964 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region ![]() ![]() |
Start mounting it in different places on your car, record some drives and review the results. If you mount it outside your car, attach a lanyard as a backup.
FlacaProductions |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,970 Joined: 24-November 17 From: LA Member No.: 21,628 Region Association: Southern California ![]() ![]() |
I use these all the time for professional purposes (although I prefer Sony ActionCams) and while I haven't mounted one on my 914 for personal use, I'd suggest trying it on the inside of the rear window facing forward. You should be able to see a nice combo of the road and hood along with the gauges and wheel/shifter and maybe a little bit of the passengers.
This should work well with the top on but might even be better with the top off. I much prefer window glass and a suction cup mount to anything. Paint on a flat surface as a second choice - also with a suction cup - and then the adhesive mounts are last. If you can go on top of the roll bar with the top off - that might be better but would limit your mounting options and prevent you from putting the top on quickly. If it's inside, you just put the top on and you're done. Inside the cabin would limit wind noise and pick up a little engine sound along with cabin conversation to a point. One thing - I almost always externally power any action cam. You might have to make sure that your unit can do that - it may just be a setting that needs to be activated. Batteries on those things are notoriously short-lived and seem to die at the worst time. a long usb cable with the appropriate connections to the cig lighter and you're good to go. I'd shoot 1080/30fps (29.97) as it'll look a little more "cinematic" - 60fps (59.94) will look a little more "video-y" - but that's a matter of your preferences. 4k will chew card space and make unwieldy-sized files and probably make the camera overheat and shut down. oh - and if you mount it on the outside, tether it. trust me. ![]() |
Carl La Fong |
Member ![]() ![]() Group: Retired Members Posts: 137 Joined: 27-March 19 From: west Member No.: 23,000 Region Association: None ![]() |
This was taken about 8 years ago with one of the first go pro cameras. It was mounted on the rear window with a suction cup. I wonder where that car is now? https://www.youtube.com/watch?v=AYiT2sqpnQc
FlacaProductions |
Not surprising. That's about how I envisioned it - although that's 4x3 and today in 1080, it'll be 16x9.
Carl La Fong |
Not surprising. That's about how I envisioned it - although that's 4x3 and today in 1080, it'll be 16x9. 1080, 2080, whatever it takes. (IMG:style_emoticons/default/av-943.gif) (IMG:style_emoticons/default/lol-2.gif) (I guess you had to see the movie). (IMG:style_emoticons/default/laugh.gif) |
mepstein |
When I sold them at the shop, we always suggested additional storage and batteries. You have to buy high speed storage, not the cheapest memory that you can find. The battery that's included last about 20 minutes. The USB cable is a good idea. Test everything before the WCR.
preach |
Ridge Runner ![]() ![]() ![]() Group: Members Posts: 1,047 Joined: 27-March 10 From: Live Free or Die Member No.: 11,513 Region Association: North East States ![]() ![]() |
On my cayman I mount it just on the passenger side of the rearview mirror. I still get some of the front fenders and a great view of the road.
Edit: I put it there, in part, due to the rearview impairs my right turn vision some so it is kind of hidden in that mess and not screwing my vision elsewhere. |
StratPlayer |
StratPlayer ![]() ![]() ![]() ![]() Group: Members Posts: 3,336 Joined: 27-December 02 From: SLC, Utah Member No.: 27 Region Association: Rocky Mountains ![]() ![]() ![]() |
I will have my go pro there as well. Be a lot of video’s of this event. (IMG:style_emoticons/default/biggrin.gif)
dan10101 |
TORQUE-o-holic ![]() ![]() ![]() Group: Members Posts: 1,140 Joined: 29-April 03 From: Eagle Point, Or Member No.: 626 Region Association: Pacific Northwest ![]() |
I second the front windshield. Inside will reduce wind noise and give some engine sound.
Plus you will have a free view of the other cars 3 or 4 deep around the corners. In my car I'll have my mirror camera with rear facing camera, plus another on the back window facing forward. Whatever you do I too recommend trying it out before the day as things happen fast and it's hard to remember or know when it on or off. I have several drives where I thought I was turning it on and actually turning it off. |
oldschool |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 3,374 Joined: 29-October 08 From: P-town Member No.: 9,705 Region Association: Southern California ![]() |
If you want to chat about the drive put inside the front windshield, put one hanging on the outside of the passenger door racking the front.
ask me how I know. (IMG:style_emoticons/default/flag.gif) |
914_teener |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,266 Joined: 31-August 08 From: So. Cal Member No.: 9,489 Region Association: Southern California ![]() |
On my cayman I mount it just on the passenger side of the rearview mirror. I still get some of the front fenders and a great view of the road. Edit: I put it there, in part, due to the rearview impairs my right turn vision some so it is kind of hidden in that mess and not screwing my vision elsewhere. (IMG:style_emoticons/default/thisthreadisworthlesswithoutpics.gif) |
campbellcj |
I can't Re Member ![]() ![]() ![]() ![]() Group: Members Posts: 4,633 Joined: 26-December 02 From: Agoura, CA Member No.: 21 Region Association: Southern California ![]() ![]() |
I have always used the inside upper-center windshield area, upside-down. (You set the camera for this.) This gives a good panoramic view of the driver's field of vision and the front-end of the car.
76-914 |
I have always used the inside upper-center windshield area, upside-down. (You set the camera for this.) This gives a good panoramic view of the driver's field of vision and the front-end of the car. Thx for all the good replies. I had tried it on the rear glass but the wind noise was severe. I like the idea of mounting it on the front windshield and will do so. Also, the long USB cable is a good tip. See ya'll there. (IMG:style_emoticons/default/beerchug.gif) |
sixnotfour |
914 Wizard ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 10,909 Joined: 12-September 04 From: Life Elevated..planet UT. Member No.: 2,744 Region Association: Rocky Mountains ![]() ![]() ![]() |
hopefully if it flies off you get it back.... (IMG:style_emoticons/default/beerchug.gif)
Attached image(s) ![]() |
cwpeden |
Great White North, huh? ![]() ![]() ![]() Group: Members Posts: 916 Joined: 20-August 06 From: Victoria BC Member No.: 6,693 Region Association: Canada ![]() |
Wont stick to rear window defogger. Unless you can find a small enough suction cup to fit between elements.
76-914 |
Hah! I'd forgotten about that pic. I don't think I'll ever mount it on the outside after reading the above comments! (IMG:style_emoticons/default/beerchug.gif) |
StratPlayer |
I mount mine on the outside all the time. Never had any problems.
Lo-Fi Version | Time is now: 12th July 2025 - 11:36 AM |
