| Tjmrfe |
Jun 12 2019, 09:23 AM
NON IMPEDING RATIONE COGITATIONIS ![]() ![]() Group: Members Posts: 132 Joined: 10-April 15 From: Cornwall on Hudson, New York Member No.: 18,612 Region Association: North East States |
Hey Guys, couldn’t take the leaking oil anymore....so, in a bold move, I decided to pull the motor! I’ve got everything sorted, all my ground straps and wiring is off...went down the check list, got my Tangerine plate and my dolly...now all I need is a guide, or two?...I’m more than willing to throw a BBQ together and refreshments I’m thinking the second weekend in July? 13/14....either day works...should not take too long, just four bolts right? Lol...I’m in Cornwall NY near West Point...PM me if you’ve got a free few hours that weekend, this way I can get it out and see how bad the oil leaks are!...
| ndfrigi |
Jun 12 2019, 09:31 AM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,978 Joined: 21-August 11 From: Orange County Member No.: 13,474 Region Association: Southern California
you’re almost there to drop your engine. For sure you can do it by yourself.
Is your current lifter can drop your engine all the way down a furniture dolly and the highest to raise your car (rear valance) can get around 29”? so you can pull the engine. (engine and dolly height is around 28”) Or use 2 floor jack to raise and lower your rear car during the engine removal. 1. All cables remove like clutch , accelerator, speedo 2. All wirings to top engine (F.I. or carb) 3. Tranny ground strap 4. Remove exhaust (it is fine also not removing it but easier and more space to work underneath) 5. Raise your rear a little bit enough for your to work underneath. 6. Loosen the tranny and engine mount bolts just enough for you to totally remove them later 7. Put your furniture dolly under the rear (vertical way of ur dolly) 8. Drop your rear slowly one side at a time (if using 2 floor jack) until the engine touches your dolly (engine mount drop to one side of the padding of your dolly and rear end of dolly pad along tranny and you may need a small wood block for dolly to tranny) Note: check also your rotor that may hit the floor 9. Drop rear that engine is totally seated to your dolly. Note again: Check again if rotor is not hitting the floor. 10. Remove engine and tranny bolts. 11. Raise your rear car slowly and always check on top your engine bay to see if clearance are all okay. You may use 2 jack stand just for additional security but don’t forget to lower the floor jack every time you lower your rear until no enough space for the jack stand and you can just put them aside 12. Pull engine out |
| Tjmrfe |
Jun 12 2019, 09:43 AM
you’re almost there to drop your engine. For sure you can do it by yourself. Is your current lifter can drop your engine all the way down a furniture dolly and the highest to raise your car (rear valance) can get around 29”? so you can pull the engine. (engine and dolly height is around 28”) Or use 2 floor jack to raise and lower your rear car during the engine removal. I took off the rear valance, and was figuring that lowering the car down to the dolly, removing the bolts, and lifting the car away from the motor would be the safest. Thanks for the height info...I’ll have to see how high that lift gets. I’m pretty sure she’s gonna make it... |
| JOEPROPER |
Jun 12 2019, 10:07 AM
The answer is "no" unless you ask... ![]() ![]() ![]() Group: Members Posts: 1,209 Joined: 21-November 15 From: White Plains New York Member No.: 19,387 Region Association: North East States
I wish I had some time. I could use a drive over Bear Mountain... You're almost there. Take your time and be safe about it.
| rhodyguy |
Jun 12 2019, 10:34 AM
Chimp Sanctuary NW. Check it out. ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 22,252 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch |
I use the 2 jack method raising under the control arms (rear tires off of the car). X2 for the dolly. Approx match the angle of the car when almost fully lowered and add some dunnage on the front of the dolly. If you have carbs, remove the carbs from the intakes leaving the linkage intact. This preserves your current adjustment. Just loosen the engine and trans attachment points. It's easier than you might think.
| rgolia |
Jun 12 2019, 01:23 PM
GeoJoe ![]() ![]() ![]() Group: Members Posts: 720 Joined: 5-February 10 From: PA Member No.: 11,329 Region Association: North East States
I think a group of 914 guys are meeting in Chester NY that weekend. I am sure someone can come by and help you out, if you are not comfortable doing it yourself. BTW - What you have left to do is the easy part.
| Big Len |
Jun 12 2019, 02:54 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,779 Joined: 16-July 13 From: Edgewood, New Mexico Member No.: 16,126 Region Association: Southwest Region |
We'll figure out a way to help you out. PM your phone number to me.
| iankarr |
Jun 12 2019, 03:03 PM
The wrencher formerly known as Cuddy_K ![]() ![]() ![]() ![]() Group: Members Posts: 2,595 Joined: 22-May 15 From: Heber City, UT Member No.: 18,749 Region Association: Intermountain Region
I’m in northern Westchester and am happy to come by and help. If you haven’t seen it already, my engine drop video is in the list on the link in my sig below...
| injunmort |
Jun 12 2019, 04:02 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,024 Joined: 12-April 10 From: sugarloaf ny Member No.: 11,604 Region Association: North East States |
i'm free. lets do it before mid july, then you can drive over to tech sesh/bbq. I am 20 minutes away. pm me. if you need tools, jacks/stands/dolly let me know.
| rhodyguy |
Jun 12 2019, 04:23 PM
Problem solved!!! Great bunch of people.
| dabird |
Jun 12 2019, 04:34 PM
Member ![]() ![]() Group: Members Posts: 94 Joined: 17-October 14 From: New Albany, IN Member No.: 18,025 Region Association: None |
I grew up in Orange County, NY. This thread is making me homesick
| Big Len |
Jun 12 2019, 04:58 PM
i'm free. lets do it before mid july, then you can drive over to tech sesh/bbq. I am 20 minutes away. pm me. if you need tools, jacks/stands/dolly let me know. (IMG:style_emoticons/default/piratenanner.gif) (IMG:style_emoticons/default/aktion035.gif) (IMG:style_emoticons/default/smilie_pokal.gif) (IMG:style_emoticons/default/pray.gif) |
| rgalla9146 |
Jun 12 2019, 07:57 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 4,950 Joined: 23-November 05 From: Paramus NJ Member No.: 5,176 Region Association: None
I saw Ian at Bear Mt. tonight and he mentioned your post. Can you handle about 10 eager helpers ? I'm in too. Rory PS ..your car looks great. |
| bigkensteele |
Jun 12 2019, 08:31 PM
Major Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,200 Joined: 30-August 04 From: Cincinnati, OH Member No.: 2,660 Region Association: South East States
I do it by myself. I use a jack under the engine bar to replace each outer mount bolt with a long piece of 3/8" threaded rod, two flat washers and 3 nuts (two on top locking each other and one on the bottom. Replace each side and tighten all the way.
Put jack under rear of transmission and slowly lower each side of the engine bar by using a ratchet wrench on the bottom nut of the threaded rod. Lower the rear of the trans as needed. This method allows very precise control of the drop which is nice if you still have your fuel injection intact since the clearance on the sides is pretty tight. ... Or have a couple of guys over and get to know some fellow 914 enthusiasts! |
| Tjmrfe |
Jun 13 2019, 05:26 AM
Wow, as expected, you guys couldn’t have been more helpful. Looks like I’ll get by with a little help from my friends! Thank you and hopefully my next picture will be back behind the wheel...thanks again...
Terry. |
| mepstein |
Jun 13 2019, 05:39 AM
914-6 GT in waiting ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 20,587 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region
Get a Tangerine jack plate and make it an easy, one person effort. Most people only regret not buying one sooner.
http://www.tangerineracing.com/tools.htm Attached image(s)
| BeatNavy |
Jun 13 2019, 05:52 AM
Certified Professional Scapegoat ![]() ![]() ![]() ![]() Group: Members Posts: 2,962 Joined: 26-February 14 From: Easton, MD Member No.: 17,042 Region Association: MidAtlantic Region
Most people only regret not buying one sooner. (IMG:style_emoticons/default/agree.gif) Cornwall is a pretty place. Tackling 9W over Storm King in a teener would be a blast. |
| Tjmrfe |
Jun 13 2019, 05:58 AM
| IronHillRestorations |
Jun 13 2019, 06:45 AM
I. I. R. C. ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 6,926 Joined: 18-March 03 From: West TN Member No.: 439 Region Association: None
+1 on the Tangerine engine plate, but you'd need 3 floor jacks. I'm so spoiled with my 2 post hoist.
| bdstone914 |
Jun 13 2019, 07:00 AM
bdstone914 ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,280 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 |
@Tjmrfe
I would be very interested to see if the Quik Jack can lift the car high enough to clear the engine coming out the back. Removing the filler neck reduces the engine hieght. It can be done alone but it good to have a helper to watch that it comes out well with nothing catching. And do you have those rubber blocks for thto give a couples inches more height. Bruce |
Lo-Fi Version | Time is now: 2nd April 2026 - 12:41 PM |
