CV Assembly, How to disassemble? |
Highland |
Jul 9 2019, 06:06 PM
Senior Member Group: Members Posts: 513 Joined: 8-August 11 From: San Diego, CA Member No.: 13,418 Region Association: Southern California |
Can someone tell me how to disassemble this CV? It's locked together and won't budge.
I already have it off the axle. |
bobboinski |
Jul 9 2019, 06:12 PM
Member Group: Members Posts: 198 Joined: 23-April 16 From: Petaluma Member No.: 19,929 Region Association: Northern California |
https://www.youtube.com/watch?v=LsytyVzokBg
Mine came apart pretty easily. Trickier going back together. |
Highland |
Jul 9 2019, 06:29 PM
I think this one may have been assembled incorrectly so it's locked up and will not rotate. Anybody have a clue how to disassemble or is this thing scrap. All parts are new.
bobboinski |
Jul 9 2019, 06:44 PM
I would put it on the splines and try tapping the the outer ring with a mallet to try to get it to pop loose.
Rob-O |
Jul 9 2019, 08:09 PM
Senior Member Group: Members Posts: 1,252 Joined: 5-December 03 From: Mansfield, TX Member No.: 1,419 Region Association: Southwest Region |
Have you taken off the snap rings at each end of the axle? In the pic above I see the ends of the snap ring with holes in the end. Snap ring off, CV comes right off.
rgalla9146 |
Jul 9 2019, 08:13 PM
Advanced Member Group: Members Posts: 4,560 Joined: 23-November 05 From: Paramus NJ Member No.: 5,176 Region Association: None |
I think this one may have been assembled incorrectly so it's locked up and will not rotate. Anybody have a clue how to disassemble or is this thing scrap. All parts are new. Yes it is assembled incorrectly. Difficult to achieve ! Try to rotate the inner ring and outer shell in opposite directions, one toward the shaft one away from the shaft. Re-assembly requires a wide segment of the outer ring to be across from a narrow segment on the inner piece on the shaft. If it was assembled it can be disassembled. |
SirAndy |
Jul 9 2019, 08:17 PM
Resident German Group: Admin Posts: 41,662 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
Should be the reverse of this:
http://www.914world.com/bbs2/index.php?s=&...st&p=458313 (IMG:style_emoticons/default/idea.gif) |
Highland |
Jul 9 2019, 08:27 PM
Thanks for putting up with my frustration guys. Found a Pelican thread recommending tapping on the ball bearing along the race and that seem to do the trick. Reassembled and the CV seems to articulate per the video now.
Highland |
Jul 10 2019, 02:56 PM
Somewhat related; can some tell me the highest the roll pin can extend past the surface the flange presses against.
My pins press in a little less than 10mm. My stock CV's were about 8.5mm. The depth of the hole on my original CV's are about 3mm deeper than the new one. I did assemble one CV and torqued the flange (31 ft-lb). The gasket compresses where the bolts are but a little loose (very little) at the pin locations. Is this normal? Hoping I don't have the drill these holes deeper. (IMG:style_emoticons/default/sad.gif) |
mepstein |
Jul 10 2019, 03:04 PM
914-6 GT in waiting Group: Members Posts: 19,300 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
Somewhat related; can some tell me the highest the roll pin can extend past the surface the flange presses against. My pins press in a little less than 10mm. My stock CV's were about 8.5mm. The depth of the hole on my original CV's are about 3mm deeper than the new one. I did assemble one CV and torqued the flange (31 ft-lb). The gasket compresses where the bolts are but a little loose (very little) at the pin locations. Is this normal? Hoping I don't have the drill these holes deeper. (IMG:style_emoticons/default/sad.gif) Probably easier to grind the pins a little shorter. |
Lo-Fi Version | Time is now: 29th May 2024 - 03:12 AM |
