L-jet 1.8 injector options, anyone used these ? |
porschetub |
Jul 10 2019, 02:15 PM
Advanced Member Group: Members Posts: 4,704 Joined: 25-July 15 From: New Zealand Member No.: 18,995 Region Association: None |
Found these on ebay for a set of 4 or other sellers have them individually,Standard Intermotor injector # FJ6-4 listed for a few other VW's also,411/412 and FI Beetle for example.
Seems to be listed by several vendors but some only list #FJ6 for the same application so don't really why there is 2 part numbers ?. Would be interested on opinions from those that have used them,need to know before buying TIA. |
914Sixer |
Jul 10 2019, 04:08 PM
914 Guru Group: Members Posts: 8,900 Joined: 17-January 05 From: San Angelo Texas Member No.: 3,457 Region Association: Southwest Region |
How about a set of real Bosch for $34.95 each? They are in WorldParts box though. EBAY Item 183609087302
jcd914 |
Jul 10 2019, 05:36 PM
Advanced Member Group: Members Posts: 2,081 Joined: 7-February 08 From: Sacramento, CA Member No.: 8,684 Region Association: Northern California |
listed for a few other VW's also,411/412 and FI Beetle for example. Any injector that fits a 411/412 which are D-jet engines does not work for a 1.8L L-jet engine. I don't know what injector the FI bugs used but I think they were L-jet. So it seem the listing you are quoting from is confused since the injectors used for L-jet and D-jet are different. Jim |
JeffBowlsby |
Jul 10 2019, 05:49 PM
914 Wiring Harnesses Group: Members Posts: 8,527 Joined: 7-January 03 From: San Ramon CA Member No.: 104 Region Association: None |
The Standard FJ6 is supposedly a replace for the L-jet 74-75 1.8L injectors according to the PN they list in their advertisements.
Attached image(s) |
porschetub |
Jul 10 2019, 07:47 PM
listed for a few other VW's also,411/412 and FI Beetle for example. Any injector that fits a 411/412 which are D-jet engines does not work for a 1.8L L-jet engine. I don't know what injector the FI bugs used but I think they were L-jet. So it seem the listing you are quoting from is confused since the injectors used for L-jet and D-jet are different. Jim Thanks Jim ,could be my bad I will check the listing and yes you are right D-jet don't work but certain about the beetle ones,shame really as I have a plenty of D-jet ones (IMG:style_emoticons/default/sad.gif) . Thanks to Jeff also ,will do further research,my eyes were bleeding after last time I searched (IMG:style_emoticons/default/lol-2.gif) . |
Jmkorfha |
Jul 10 2019, 08:22 PM
I'm not a singing grandpa. Group: Members Posts: 59 Joined: 26-October 13 From: Austin, Mn Member No.: 16,569 Region Association: Upper MidWest |
Autozone has Gp Sorenson fuel injectors that fit. I installed one a couple weeks ago and it runs perfect. About $60 and came next day.
Of course mine is djet. They list another part number for 1.8. |
porschetub |
Jul 10 2019, 10:16 PM
Mark thanks for that and the contact/link,will look that way but checked on the Standard website and Jeff is correct so most likely go that way.
Yes the listing is a bit odd but the right part number is there so that's good appears they are a surplus car part clearing house so maybe that's the mix up...have had this before on ebay. Cheers all. |
Lo-Fi Version | Time is now: 3rd June 2024 - 06:12 AM |
