| advman89 |
Jul 22 2019, 09:11 PM
Member ![]() ![]() Group: Members Posts: 120 Joined: 8-July 19 From: Chicago, IL Member No.: 23,286 Region Association: Upper MidWest
Does this look correct? This is on the passenger side, in front of the rear tire. I had been looking for something like the Mahle canister.
(Sorry for the bad pic!) Pelican sent me a Mahle filter...round, not square...can I use this? Part# 311-133-511-D-M67 Mahle KL 11 OF 1971 Car, 2.0 with some various bits from a 1975...just trying to sort what's what. |
| JawjaPorsche |
Jul 23 2019, 04:32 AM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 3,463 Joined: 23-July 11 From: Clayton, Georgia Member No.: 13,351 Region Association: South East States |
The original location of the fuel pump and filter were not an idea location. Not only change the fuel filter down there but the fuel hoses to avoid fires. Get High pressure fuel hoses. The original filters were square. Also get the correct fuel hose clamps too.
| advman89 |
Jul 23 2019, 08:27 PM
Thank you...
Guess that full fuel line hose replacement is happening...I've seen one too many of these up in flames. I have a note to Tangerine (Chris Foley) to see which set I should get. Let's go tank to injectors! |
| advman89 |
Aug 25 2019, 10:31 AM
Ugh.
I'm hoping someone can help! Where is the damn fuel pump? 1971 914. 1975 2.0 and various bits... The fuel filer is the boxy one, under the car...but need locate it so I can order lines. I just pullled up the gas tank and I don't see it under there. I thought that's where I'd find it. Is it the shiny silver pump here? ![]() |
| dabird |
Aug 25 2019, 10:51 AM
Member ![]() ![]() Group: Members Posts: 94 Joined: 17-October 14 From: New Albany, IN Member No.: 18,025 Region Association: None |
Take the plate off that's covering the steering rack underneath the front of the car . It's probably been relocated to there
| SirAndy |
Aug 25 2019, 11:06 AM
Resident German ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 42,473 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
On a '71 the fuel pump is under the pass. side engine shelf near where you found the fuel filter. Follow the fuel lines from the filter and you should find it.
That shiny round thing on top of your engine is the mps sensor which should be mounted to the small bracket next to the battery tray. (IMG:style_emoticons/default/popcorn[1].gif) |
| advman89 |
Aug 26 2019, 09:45 AM
Thanks everyone. This car is so much the flipside from my 911...I wanted a project...and I got it.
I didn't think that was the pump, but figured I'd ask. Someone was trying to convince me otherwise. I'll follow the lines from the filter, but if it's in there, is buried up pretty good, I cant see anything on first/second glance. All I need is a confirmation to make the order with Chris F. Is there a place in the engine bay (or more accessable location) people relocate the pump and filter? |
| VaccaRabite |
Aug 26 2019, 10:10 AM
En Garde! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 13,845 Joined: 15-December 03 From: Dallastown, PA Member No.: 1,435 Region Association: MidAtlantic Region
Yes, but not in the engine bay!
It has to be low - lower then the gas tank or there isnt any fuel gravity fed to the pump. Its own issue. most people relocate them to the front trunk under the gas tank, or under the front trunk near the steering rack. The factory changed the location in 75-76 cars and had an opening low on the pass side of the front trunk under the tank, and many people re-create that with earlier cars. Its a much better set up. Zach |
| SirAndy |
Aug 26 2019, 11:55 AM
The factory changed the location in 75-76 cars and had an opening low on the pass side of the front trunk under the tank, and many people re-create that with earlier cars. Its a much better set up. One thing to consider when relocating the fuel pump to the front: With the old stock setup the plastic lines through the center tunnel were LOW pressure with the pump sucking fuel through them and the filter, then building pressure in only a short run of fuel lines from just under the engine shelf. If you relocate the pump (and filter) to the front, you are now running HIGH pressure through 40 year old plastic fuel lines that were never designed to handle such pressure. When i did my conversion, i had to mount the pump under the tank (993 pumps aren't good at sucking) so i replaced the plastic lines with the stainless steel fuel lines through the center tunnel. (IMG:style_emoticons/default/shades.gif) |
| ClayPerrine |
Aug 26 2019, 12:03 PM
Life's been good to me so far..... ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 16,542 Joined: 11-September 03 From: Hurst, TX. Member No.: 1,143 Region Association: NineFourteenerVille
The factory changed the location in 75-76 cars and had an opening low on the pass side of the front trunk under the tank, and many people re-create that with earlier cars. Its a much better set up. One thing to consider when relocating the fuel pump to the front: With the old stock setup the plastic lines through the center tunnel were LOW pressure with the pump sucking fuel through them and the filter, then building pressure in only a short run of fuel lines from just under the engine shelf. If you relocate the pump (and filter) to the front, you are now running HIGH pressure through 40 year old plastic fuel lines that were never designed to handle such pressure. When i did my conversion, i had to mount the pump under the tank (993 pumps aren't good at sucking) so i replaced the plastic lines with the stainless steel fuel lines through the center tunnel. (IMG:style_emoticons/default/shades.gif) (IMG:style_emoticons/default/agree.gif) Replace the plastic lines. Don't end up standing on the side of the road watching your 914 burn. Betty and I watched her car burn. It was heartbreaking, and almost cost us our marriage. Took a few years before I could face rebuilding the car. I would even recommend replacing them if you keep the fuel pump in the stock location. I did that to our factory six right after we got it. It is the only non-reversible thing we have done to that car. And it was done purely for safety. |
| advman89 |
Aug 26 2019, 12:30 PM
Plan is to replace all the lines...tank to injectors...I saw stacks of 914s burned up in a Porsche graveyard in Phoenix in the early 2000's.
Chris F. is already on speed dial for this one! |
| Jamie |
Aug 26 2019, 05:25 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,204 Joined: 13-October 04 From: Georgetown,KY Member No.: 2,939 Region Association: South East States
The factory changed the location in 75-76 cars and had an opening low on the pass side of the front trunk under the tank, and many people re-create that with earlier cars. Its a much better set up. One thing to consider when relocating the fuel pump to the front: With the old stock setup the plastic lines through the center tunnel were LOW pressure with the pump sucking fuel through them and the filter, then building pressure in only a short run of fuel lines from just under the engine shelf. If you relocate the pump (and filter) to the front, you are now running HIGH pressure through 40 year old plastic fuel lines that were never designed to handle such pressure. When i did my conversion, i had to mount the pump under the tank (993 pumps aren't good at sucking) so i replaced the plastic lines with the stainless steel fuel lines through the center tunnel. (IMG:style_emoticons/default/shades.gif) t What material did the factory use for fuel lines through the tunnel when fuel pump was relocated to the front? |
| advman89 |
Aug 26 2019, 06:21 PM
Found. It's under the car, by the rear passenger tire.
So. Since I'm doing everything anyway...should I plan to relocate the pump and filter under the tank? |
| tmc914 |
Aug 26 2019, 09:16 PM
Member ![]() ![]() Group: Members Posts: 116 Joined: 24-September 17 From: Lowell, MA Member No.: 21,452 Region Association: North East States
| 914werke |
Aug 27 2019, 10:00 AM
"I got blisters on me fingers" ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 11,624 Joined: 22-March 03 From: USofA Member No.: 453 Region Association: Pacific Northwest
What material did the factory use for fuel lines through the tunnel when fuel pump was relocated to the front? Not exactly sure. It has been discussed before & you may be able to find it with a search of the board but the two types of lines are easily distinguished. The early lines are clear/opaque while the late Hi-pres lines are Black. |
| VaccaRabite |
Aug 27 2019, 11:10 AM
What material did the factory use for fuel lines through the tunnel when fuel pump was relocated to the front? Not exactly sure. It has been discussed before & you may be able to find it with a search of the board but the two types of lines are easily distinguished. The early lines are clear/opaque while the late Hi-pres lines are Black. Pretty sure they used the same center tunnel lines regardless of where the fuel pump was. My 76 had the clear/opaque lines and the factory mounted front pump. That said, I pulled those lines out and replaced them with SS from Chris before i ever fired the motor on my car. The lines in my BMW '75 2002 were the same exact material. I'm replacing them as well. the theory in the BMW community is that in the event of a fire, the plastic would melt closed and keep new fuel from feeding a fire in the cabin. Ha ha ha, good one Potsy. Going to metal lines in the '02 as well and not routing them through the cabin. The plastic tunnel lines were never designed for ethanol. Everyone should pull them and replace them. I have a picture of a plastic fuel filter that was on my car when it had carbs, and the plastic is sagging due to ethanol. Scary. Zach |
| 914werke |
Aug 27 2019, 12:35 PM
Nope. I dont know what went on with your car Zach but indeed they ARE different early to late.
But I do agree, none were probably designed to withstand the significant Ethanol blends that are the standard at pumps today. |
| ClayPerrine |
Aug 29 2019, 08:51 PM
The lines in my BMW '75 2002 were the same exact material. I'm replacing them as well. the theory in the BMW community is that in the event of a fire, the plastic would melt closed and keep new fuel from feeding a fire in the cabin. Ha ha ha, good one Potsy. Going to metal lines in the '02 as well and not routing them through the cabin. Having gone through an engine fire, I can tell you for sure that the plastic lines won't melt closed, they just melt holes in the lines so the gasoline can feed the fire! |
Lo-Fi Version | Time is now: 15th April 2026 - 09:58 PM |
