WTB - Ducting for Heat Backdate, Backdating 1975 1.8L Heat Exchangers |
moldygreg |
Jul 24 2019, 09:47 AM
Stay Golden Group: Members Posts: 135 Joined: 13-December 12 From: Seattle Member No.: 15,253 Region Association: Pacific Northwest |
Hi all-
I have sourced 2.0L Stainless Steel Heat Exchangers to get rid of the original 1975 Heat Exchangers. I belive I need the following: Heater ducting, including --S-ducts from fan shroud to exchangers --J-tubes from topside hoses to S-ducts --Pipes from exchangers to "flapper valves" Appreciate help if anyone has done this successfully before. Many thanks in advance, Greg |
DRPHIL914 |
Jul 24 2019, 10:42 AM
Dr. Phil Group: Members Posts: 5,768 Joined: 9-December 09 From: Bluffton, SC Member No.: 11,106 Region Association: South East States |
Hi all- I have sourced 2.0L Stainless Steel Heat Exchangers to get rid of the original 1975 Heat Exchangers. I belive I need the following: Heater ducting, including --S-ducts from fan shroud to exchangers --J-tubes from topside hoses to S-ducts --Pipes from exchangers to "flapper valves" Appreciate help if anyone has done this successfully before. Many thanks in advance, Greg I have some if not all of those parts, the J-tubes for sure and they are inexcellent condition and primed ready for you to repaint. - no clean up or degreasing! I may have a set of the S-ducts as well. I have the gaskets too I believe. I also did the back date when I put on the 2.0 HE rather than the '75 late stuff. you will be glad you did this. PM me your email and I can sent you pics tonight. I can box and ship, minimal cost just cost of shipping when we weigh it, shouldn't be to bad - we can talk price I don't even have a price in mind, just make a fair offer if you are ok with that. Dr. Phil. |
rhodyguy |
Jul 24 2019, 11:18 AM
Chimp Sanctuary NW. Check it out. Group: Members Posts: 22,093 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch |
Ensure you get the correct clamping covers for the S ducting. You will also need the warm air elbow and L(late)&R warm air guides. If you can get the L AND R versions WAE it will help with the valve control wire.
ClayPerrine |
Jul 25 2019, 10:00 AM
Life's been good to me so far..... Group: Admin Posts: 15,526 Joined: 11-September 03 From: Hurst, TX. Member No.: 1,143 Region Association: NineFourteenerVille |
I have multiple sets of the heater ducting.
Let me know what you need. |
Chi-town |
Jul 25 2019, 10:57 AM
Most of it's available new from Dansk.
I would do the valves new as the seals on used ones are usually toast |
moldygreg |
Jul 26 2019, 09:40 AM
Sourced! Thanks @rhodyguy -- was a beautiful drive to South Sound last night.
Mt. Rainier is majestic! Greg |
PanelBilly |
Jul 26 2019, 10:32 AM
914 Guru Group: Members Posts: 5,817 Joined: 23-July 06 From: Kent, Wa Member No.: 6,488 Region Association: Pacific Northwest |
I have a box of that stuff too. If there's anything that Kevin missed, let me know
rhodyguy |
Jul 26 2019, 11:07 AM
He needs the pass side warm air guide. I only had the dr side. 914rubber offers affordable gaskets for the covers. Prior, I refused to the buy the expensive ones, I laid some beads of RTV, let it set up and the covers sealed just fine.
rhodyguy |
Jul 28 2019, 07:38 AM
A bump for Greg. He needs a early version pass side warm air guide to complete his setup.
moldygreg |
Jul 30 2019, 07:49 PM
DRPHIL914 |
Aug 3 2019, 03:18 PM
A bump for Greg. He needs a early version pass side warm air guide to complete his setup. Thanks. Yes, I need the early passenger warm air guide --- thanks! I have one! Sorry I didn’t get back to you on the other parts but I have this early guide that I believe I bought from Rhodguy too when I was doing my back dating but I have later shift rod- if you have the tail shifter linkage this should be what you need Attached thumbnail(s) |
rhodyguy |
Aug 3 2019, 03:50 PM
That's a dr side. The pass side has a squarish channel rather than the up or down curve.
DRPHIL914 |
Aug 3 2019, 03:54 PM
That's a dr side. The pass side has a squarish channel rather than the up or down curve. (IMG:style_emoticons/default/mad.gif) (IMG:style_emoticons/default/headbang.gif) I knew that , I need to learn to read arg!! Didn’t even see the passenger vs driver - ok -anyway Kevin I got this from you LOL and need to pass it on cuz I don’t need it. Good luck with search for the other side- I don’t think I have one of those but I have everything else! |
theer |
Aug 4 2019, 09:50 PM
Senior Member Group: Members Posts: 677 Joined: 31-July 15 From: Dover, MA Member No.: 19,014 Region Association: North East States |
I thought the pass side warm air guides were all the same? What's the diff early vs late?
rhodyguy |
Aug 5 2019, 08:00 AM
The 75-76 HE WAGs are completely dif. Newmerous components differ when backdating to early HEs.
moldygreg |
Aug 5 2019, 06:06 PM
carl k |
Aug 5 2019, 07:34 PM
Member Group: Members Posts: 76 Joined: 19-August 08 From: San Jose, CA Member No.: 9,440 Region Association: None |
moldygreg |
Aug 6 2019, 03:36 PM
Lo-Fi Version | Time is now: 12th June 2024 - 12:03 AM |
