Outer CV removal while in car? |
bretth |
Aug 8 2019, 05:36 AM
Senior Member Group: Members Posts: 899 Joined: 23-June 15 From: Central TX Member No.: 18,882 Region Association: Southwest Region |
Anyone have a method for removing outer CV joints while still on car? My trans is out and just the shafts are still connected. I want to flat tow the car without engine, trans, or drive shafts.
IronHillRestorations |
Aug 8 2019, 06:14 AM
I. I. R. C. Group: Members Posts: 6,731 Joined: 18-March 03 From: West TN Member No.: 439 Region Association: None |
I've only been successful at that once, and it was harder that just pulling the entire half shaft, which can also be a hassle if you don't have the right tools.
GregAmy |
Aug 8 2019, 06:29 AM
Advanced Member Group: Members Posts: 2,311 Joined: 22-February 13 From: Middletown CT Member No.: 15,565 Region Association: North East States |
See if you can find a pair of stub axles sitting around in someone's garage (I keep a pair in the parts box for such contingencies).
Mark Henry |
Aug 8 2019, 06:37 AM
I had to do an emergency outboard CV bolt repair on PatrickB's car last weekend, no problem removing the half shaft even with the trans in. You have to sneak the shaft over the trans to pull it out.
R&R drivers side half shaft, chase the threads on the stub and torque all the CV bolts didn't take me more than 2 hours. |
David Billo |
Aug 8 2019, 06:52 AM
Member Group: Members Posts: 64 Joined: 23-November 17 From: Plainfield, Ontario Member No.: 21,625 Region Association: Canada |
But, how, I think, is the question. It's near impossible to get anything in there to coax the CV joint off the stub axle flange. Even after removing the bolts, they are very tightly mated to the stub. What did you use, Mark? My understanding is that the stub needs to be pulled so you can pry them off on the bench, but can you back off the castle nut and pound on it from the outside?
I tried to remove one of mine (stupidly) by using the half axle like a slide hammer. This popped the circlip off the end of the shaft, but I DON'T RECOMMEND this method, as I think it might be just as likely to break the circlip, or worse, chip a piece off the end of the shaft. And, of course, the CV joint is still on there. |
GregAmy |
Aug 8 2019, 07:03 AM
Mark Henry |
Aug 8 2019, 07:08 AM
But, how, I think, is the question. It's near impossible to get anything in there to coax the CV joint off the stub axle flange. Even after removing the bolts, they are very tightly mated to the stub. What did you use, Mark? My understanding is that the stub needs to be pulled so you can pry them off on the bench, but can you back off the castle nut and pound on it from the outside? I tried to remove one of mine (stupidly) by using the half axle like a slide hammer. This popped the circlip off the end of the shaft, but I DON'T RECOMMEND this method, as I think it might be just as likely to break the circlip, or worse, chip a piece off the end of the shaft. And, of course, the CV joint is still on there. I didn't think of that, his bolts had failed the CV was already off. I'd pull the stubs out, I have an air zip gun I put the pointy end punch in and the stubs usually hammer right out without hurting the bearing. Then remove the shaft/CV and put the stubs back in for towing. |
GregAmy |
Aug 8 2019, 07:17 AM
Generous use of anti-sieze on the splines will assist in making it an easier job "next time". Mine slide right out with a light blow from the HF BOH (Big Orange Hammer).
bretth |
Aug 8 2019, 07:28 AM
Doesn't removing the stub shaft ruin the rear bearings? It was easy for me to get the inner CVs off with just some sideways light hammer tapping. Maybe if I put a tight fitting drift into one of the bolt holes and tapped it sideways it could pop out?
rhodyguy |
Aug 8 2019, 08:19 AM
Chimp Sanctuary NW. Check it out. Group: Members Posts: 22,093 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch |
The cv can bond with the flange. Trying to separate them can be futile. Your only recourse may be to remove the large nut, I use a electric impact, on the hub and draw the whole assembly outboard thru the rear trailing arm.
914werke |
Aug 8 2019, 10:25 PM
"I got blisters on me fingers" Group: Members Posts: 10,141 Joined: 22-March 03 From: USofA Member No.: 453 Region Association: Pacific Northwest |
(IMG:style_emoticons/default/dead horse.gif)
Tools/materials necessary: 30mm socket, 3/4 breaker bar. Recommended 2' or so length of pipe sized to slide over your breaker bar handle. 3' length of 2" angle iron (7g) Step 1: Measure & drill pair of M14 holes in each end of the angle iron on opposing legs Step 2: Bolt your new tool to the face of your rear disc using the OE lugs (after you've removed the wheel (IMG:style_emoticons/default/sunglasses.gif) ) Step 3: Remove the .5 shaft from the hub complete using your socket, breaker bar & lever pipe Step 4: Separate the stub from the .5 shaft OR buy a very affordable set of spare stubs HERE (IMG:style_emoticons/default/biggrin.gif) Step 3: reinstall stub Rinse & repeat. (IMG:style_emoticons/default/biggrin.gif) |
rhodyguy |
Aug 9 2019, 02:11 PM
Aerokroil that big nut. A few treatments. Tap on it with a hammer. Let it work. Dunnage up the car so it doesn't fall off the jack stands and hit the floor when you're reefing on that cheater bar. A 1/2" drive electric impact, autozone about $50 iirc, and a hardened socket makes short work of it. Way safer.
Lo-Fi Version | Time is now: 9th June 2024 - 11:20 PM |
