Need Tach Turn Signal Bulb Holder, Part Number/Availability or does anyone have one? |
FlacaProductions |
Aug 9 2019, 09:31 PM
Senior Member Group: Members Posts: 1,607 Joined: 24-November 17 From: LA Member No.: 21,628 Region Association: Southern California |
My (single) turn signal indicator in the tach takes a BA7 LED and looks great.
I thought that the high beam indicator socket was the same type but has proved otherwise. It's for a wedge base lamp and just does NOT throw any light. I'd like to just swap in a BA7 socket and associated LED - does anyone have a source or an extra turn signal socket for a BA7 lamp? Is my high beam indicator socket incorrect as a wedge socket? |
914Sixer |
Aug 10 2019, 06:29 AM
914 Guru Group: Members Posts: 8,897 Joined: 17-January 05 From: San Angelo Texas Member No.: 3,457 Region Association: Southwest Region |
Picture of old socket would help
FlacaProductions |
Aug 10 2019, 07:13 AM
You're right - I thought about that after I posted. Of course I buttoned it all up yesterday but I'll get back in it today and snap a pic. Stupid of me...
76-914 |
Aug 10 2019, 09:49 AM
Repeat Offender & Resident Subaru Antagonist Group: Members Posts: 13,507 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California |
I probably have one. Post a pic. I'm in Temecula but could mail it to you or take it Ron's remembrance party this evening and maybe one of the LA guys attending could shuttle it to you. (IMG:style_emoticons/default/beerchug.gif)
dr914@autoatlanta.com |
Aug 10 2019, 11:03 AM
914 Guru Group: Members Posts: 7,887 Joined: 3-January 07 From: atlanta georgia Member No.: 7,418 Region Association: None |
those are commonly available, plenty in stock, it is the instrument light socket thatis the hard one to find, in the porsche parts manual it is only sold as a loom
My (single) turn signal indicator in the tach takes a BA7 LED and looks great. I thought that the high beam indicator socket was the same type but has proved otherwise. It's for a wedge base lamp and just does NOT throw any light. I'd like to just swap in a BA7 socket and associated LED - does anyone have a source or an extra turn signal socket for a BA7 lamp? Is my high beam indicator socket incorrect as a wedge socket? |
Jonathan Livesay |
Aug 10 2019, 11:15 AM
Senior Member Group: Members Posts: 742 Joined: 13-March 10 From: La Canada CA Member No.: 11,461 Region Association: None |
My (single) turn signal indicator in the tach takes a BA7 LED and looks great. I thought that the high beam indicator socket was the same type but has proved otherwise. It's for a wedge base lamp and just does NOT throw any light. I'd like to just swap in a BA7 socket and associated LED - does anyone have a source or an extra turn signal socket for a BA7 lamp? Is my high beam indicator socket incorrect as a wedge socket? The high beam light has a blue tinted lens on the instrument face, in my experience these get darker and darker until they basically don't pass any light through at all. You can achieve a faint glow with an LED bulb, but that's about it unless you have the gauge refurbished and that lens replaced. |
FlacaProductions |
Aug 10 2019, 11:24 AM
@Jonathan Livesay - You're right but I think the LED will overcome the dimming of the blue lens and is a lot easier than opening the body of the tach.
@dr914 @autoatlanta.com - I've searched your site and I can't see which is which. @76-914 & @914Sixer - I'll try to get a pic asap. I have today and tomorrow with the car so I'll see if I can get to it - thank you! |
injunmort |
Aug 10 2019, 11:40 AM
Senior Member Group: Members Posts: 1,024 Joined: 12-April 10 From: sugarloaf ny Member No.: 11,604 Region Association: North East States |
914Sixer |
Aug 10 2019, 12:24 PM
Here you go 74-76 single bulb holder. Is this the one you need? If so send me your shipping information.
Attached image(s) |
FlacaProductions |
Aug 10 2019, 12:41 PM
@914Sixer - if you look on the other side, does it have a small tab that would ground against the inside of the tach? If so....yes!
914Sixer |
Aug 10 2019, 01:39 PM
Yep, ground tab on the other side.
FlacaProductions |
Aug 10 2019, 03:05 PM
This place rocks. sending you a PM @914Sixer
Lo-Fi Version | Time is now: 2nd June 2024 - 02:36 AM |
