> Homestead race fun, windshield departed
Jetsetsurfshop
post Aug 12 2019, 04:16 PM
https://www.youtube.com/watch?v=9n_cYEX9iZk
Replies(1 - 19)
gereed75
post Aug 12 2019, 04:52 PM
Woo hooo. These things happen so fast there is little butt clinching at the time, just post event adrenaline surge! Yikes!
gereed75
fat Finger DP
Superhawk996
post Aug 12 2019, 06:45 PM
(IMG:style_emoticons/default/rolleyes.gif) That funny only because it wasn't me!
Good save from what could have been a total loss! (IMG:style_emoticons/default/piratenanner.gif) Apparently 914 windshield not designed for 100 MPH in reverse! (IMG:style_emoticons/default/happy11.gif) Hopefully suspension is OK!
Looked like you got some serious cowl flex that might have let trim come off and then wind got under a lip?
Was it recently installed? Butyl tape or Urethane?
Once told by our SCCA World Challenge champion driver that there are 3 types of crashes in racing:
1) The crew is going to be mad cleaning the grass, mud or gravel off the car.
2) The crew is going to be P*!!&d repairing the damage to the car.
3) Oh S*** this is going to hurt!
johnhora
post Aug 12 2019, 06:48 PM
just what windshield clips try to help prevent....usually
lots of air pressure there when traveling backwards at speed
glad nothing else happened during that excursion
Jetsetsurfshop
post Aug 12 2019, 08:02 PM
I was in disbelief at first. Glad the e30 driver counted on me coming back on track.
Plan on making some tabs to hold it in and I also don't plan on going backwards at 100mph again!
I did touch the wall. nothing serious. You can hear when it happens in the video.
The windshield has been in the car since I owned it. Never thought about it coming out. (IMG:style_emoticons/default/WTF.gif)
Krieger
post Aug 12 2019, 08:55 PM
Wow, yeah, shit happens fast at the track. Glad your okay. I hope the hit was minor.
Jetsetsurfshop
post Aug 13 2019, 06:42 AM
Thinking this will buff out. (IMG:style_emoticons/default/smash.gif)
falcor75
post Aug 13 2019, 07:16 AM
Wow with how quick it came out I thought you had to be running without a rear screen so the reverse airflow pushed it out rather than it being sucked out....
Krieger
post Aug 13 2019, 07:43 AM
Not too bad! Sound worse on the video.
Garland
post Aug 13 2019, 07:47 AM
Restoration Fanatic
Bought a 914 that had been sitting under a leaking hoist, had some hydraulic fluid on the top and windshield. After putting it on the flatbed backwards, we hit the freeway. After a few minutes at freeway speed I dodged to the left to avoid the flying windshield that the butyl had failed due to the hydraulic fluid soaking the seal. I watch that good original windshield smashed to bits on the side of the freeway.
Jetsetsurfshop
post Aug 27 2019, 12:14 PM
New windshield installed. Thanks to 914Rubber for the new seal. (IMG:style_emoticons/default/beerchug.gif)
post Aug 27 2019, 12:25 PM
Resident German
Add some metal tabs. Not only do they work, they look cool too ...
Chi-town
post Aug 27 2019, 01:06 PM
Was the one that flew out put in with butyle or urethane?
Jetsetsurfshop
post Aug 27 2019, 04:29 PM
Not sure what was used last time. It wasn't in there very good. The guys that installed it this time used urethane.
Will be making some tabs too.
yeahmag
post Aug 28 2019, 12:30 PM
Looked like a bit too much curb and maybe a lift that caused the spin?
Jetsetsurfshop
post Aug 28 2019, 01:18 PM
QUOTE(yeahmag @ Aug 28 2019, 10:30 AM) *
Pretty sure I didn't lift. I was determined to get around that E30. I've hit that spot plenty of times just not from that lower attack angle. When I look over video of me at that corner my car always seems to be a little upset. Lesson learned.
yeahmag
post Aug 28 2019, 02:41 PM
What are your rear spring rates? Got an LSD in the car?
Jetsetsurfshop
post Aug 28 2019, 03:44 PM
QUOTE(yeahmag @ Aug 28 2019, 12:41 PM) *
Rear springs are 225 and its currently an open diff.
Like to hear your opinion. After this happened I thought a more compliant spring would be better.
yeahmag
post Aug 28 2019, 04:43 PM
Just the opposite. I’d suggest going up to a minimum of 300lbs. All of my strange oversteer issues went away then. I may move up to 400lb or higher. What are you running up front?
- Lo-Fi Version Time is now: 31st July 2025 - 06:17 PM
