Headlight relays |
Headlight relays |
DickSteinkamp |
Aug 15 2019, 06:07 PM
Senior Member Group: Members Posts: 500 Joined: 27-February 17 From: Bellingham, WA Member No.: 20,876 Region Association: None |
1976. Are the headlight motor relays, and the relays in the relay panel in the engine compartment (power relay, fuel pump relay, heater fan relay) the same? PN 91161510901? If so, any others that are this PN?
Minerva's 914 |
Aug 15 2019, 09:36 PM
Member Group: Members Posts: 378 Joined: 24-December 15 From: Chapel Hill, NC Member No.: 19,489 Region Association: South East States |
DickSteinkamp |
Aug 15 2019, 09:47 PM
jcd914 |
Aug 15 2019, 09:55 PM
Advanced Member Group: Members Posts: 2,081 Joined: 7-February 08 From: Sacramento, CA Member No.: 8,684 Region Association: Northern California |
As best I know there are 2 maybe 3 different versions of the round 5 pin relays Porsche used.
The round black ones used in the 914 and other Porsche's,. There was also a round red version used for 911 fuel pumps that has a higher amperage rating. They all function the same just higher amperage for the red ones. I also have some white ones from a 914 and I think they are the same as the black ones. Jim |
mitchdiego1 |
Aug 16 2019, 02:47 PM
Newbie Group: Members Posts: 42 Joined: 19-May 19 From: oceanside ca Member No.: 23,145 Region Association: Southern California |
As best I know there are 2 maybe 3 different versions of the round 5 pin relays Porsche used. The round black ones used in the 914 and other Porsche's,. There was also a round red version used for 911 fuel pumps that has a higher amperage rating. They all function the same just higher amperage for the red ones. I also have some white ones from a 914 and I think they are the same as the black ones. Jim I have a question, I put a brand new relay in and my heater fans started running, replaced with a different one and they worked fine. I am thinking I have a bad relay out of the box, is the correct? |
PanelBilly |
Aug 16 2019, 03:48 PM
914 Guru Group: Members Posts: 5,820 Joined: 23-July 06 From: Kent, Wa Member No.: 6,488 Region Association: Pacific Northwest |
Yes, you get bad ones brand new
mepstein |
Aug 16 2019, 05:19 PM
914-6 GT in waiting Group: Members Posts: 19,325 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
The early cars had metal covered relays.
mitchdiego1 |
Aug 20 2019, 01:50 PM
dr914@autoatlanta.com |
Aug 20 2019, 03:26 PM
914 Guru Group: Members Posts: 7,900 Joined: 3-January 07 From: atlanta georgia Member No.: 7,418 Region Association: None |
the bad ones were made by URO, we have had many, however URO is working on improved ones and will have them shortly, right now everyone is out of stock of every variety except the genuine porsche parts which we have many but they are expensive, yet work everythim. (how is that for a run on sentence?) 91161510901
Lo-Fi Version | Time is now: 17th June 2024 - 06:03 AM |
