How much power / displacement before a front oil cooler needed? |
Tdskip |
Aug 16 2019, 11:53 AM
Advanced Member Group: Members Posts: 3,686 Joined: 1-December 17 From: soCal Member No.: 21,666 Region Association: None |
Hi guys-happy Friday to everyone. Was having a conversation this morning about various engine swap options and the topic came up of exactly how much power, or displacement, when you reach a point of needing a front mounted oil cooler.
Obviously a front mounted cooler is a bigger commitment on time and money since you need to run the lines in modify the front trunk and buy the cooler etc., Saving a couple dollars to compromise the durability of an engine is obviously a bad deal, but at what point do you think a front cooler is actually needed? Thanks! |
mepstein |
Aug 16 2019, 05:08 PM
914-6 GT in waiting Group: Members Posts: 19,305 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
At the point that the on-engine cooler can’t cut it. (IMG:style_emoticons/default/biggrin.gif)
Carreras have front coolers so I’ve always planned on one for my 3.2 conversions. In fact, I removed the cooler on the engine since the front cooler is big and has a fan assist. Just like what Porsche did when they did the 3.6 cars. I’m using Ben’s GT style hard lines on my 2nd conversation. I like them a lot. But my 1st conversation car just used stainless hose, A/N fittings and a Setrab fan pack cooler. The whole front setup was less than $1k including the oil cooler bypass plate. I drilled a couple 1” holes to run the SS hose. I use the stock holes in the front and popped out the two round access plates in the bottom of the front trunk for exhaust air.. They are just held in with seam sealer. I cut an air inlet in the stock valance. The whole setup took a couple hours and a step drill that could go to 1”. No other cutting on the body was needed. If you want the full GT look, it’s obviously more work and money. |
Tdskip |
Aug 16 2019, 05:13 PM
Damm it man, you are supposed to make it easy, don’t make me think!
For example, a 2056 seems like a no but how about a 2.2 or 2.4 Type 4? How about a 2.2 6? |
mepstein |
Aug 16 2019, 05:16 PM
There was a thread on this a week ago. Bottom line, it’s engine, location and driving style dependent.
Tdskip |
Aug 16 2019, 05:37 PM
ChrisFoley |
Aug 17 2019, 10:34 AM
I am Tangerine Racing Group: Members Posts: 7,934 Joined: 29-January 03 From: Bolton, CT Member No.: 209 Region Association: None |
We installed a 993 engine in a customer's car and chipped the ecu to make 300hp. It has dual Setrab coolers mounted under the trunk and it has no problem maintaining good oil temperatures.
Tdskip |
Thanks Chris, that thing just REALLY move!
Larmo63 |
Aug 17 2019, 10:59 AM
Advanced Member Group: Members Posts: 4,264 Joined: 3-March 14 From: San Clemente, Ca Member No.: 17,068 Region Association: Southern California |
This subject has been beaten to death, but the general consensus is 2.4 /6 no, 2.7 /6 and higher displacement engines, yes.
YMMV. |
Tdskip |
Aug 17 2019, 12:22 PM
Thanks, hope everyone is having a good Saturday.
burton73 |
Aug 17 2019, 12:57 PM
burton73 Group: Members Posts: 3,537 Joined: 2-January 07 From: Los Angeles Member No.: 7,414 Region Association: Southern California |
This subject has been beaten to death, but the general consensus is 2.4 /6 no, 2.7 /6 and higher displacement engines, yes. YMMV. (IMG:style_emoticons/default/agree.gif) Bob B |
Lo-Fi Version | Time is now: 31st May 2024 - 07:20 PM |
