New arrival at Vancouver, WA Pick & Pull, heading over to check it out |
mankowski |
Aug 17 2019, 09:44 AM
Member Group: Members Posts: 128 Joined: 7-February 10 From: Portland, Oregon Member No.: 11,335 Region Association: Pacific Northwest |
Row 52 ad says it's a 72. I will post more details about parts and condition, with photos, and add VIN to database after checking it out later this morning.
Eric |
1adam12 |
Aug 17 2019, 11:02 AM
Member Group: Members Posts: 209 Joined: 25-May 17 From: Chino Hills, CA Member No.: 21,132 Region Association: Southern California |
Good luck! Hopefully it will be worth your while and you can scoop up a few usable items. Suspect on those fenders tho if they state it's a '72.
Tbrown4x4 |
Aug 17 2019, 11:53 AM
Senior Member Group: Members Posts: 705 Joined: 13-May 14 From: Port Orchard, WA Member No.: 17,338 Region Association: None |
Mmmm those wire hubcaps! haha
I got that notification today as well. Too far on short notice. Keep us posted. |
mankowski |
Aug 17 2019, 12:34 PM
JeffBowlsby |
Aug 17 2019, 12:40 PM
914 Wiring Harnesses Group: Members Posts: 8,535 Joined: 7-January 03 From: San Ramon CA Member No.: 104 Region Association: None |
If its a late 1972, I would be interested in the main chassis harness. Its some work to get it out I realize. The late 72 I am interested in has the 14 pin connector at the steering column, not the 12 pin connector.
Let me know. |
mankowski |
Aug 17 2019, 01:58 PM
Jeff,
This is a June 72 chassis Vin number ending in 0827, so it’s just a few cars too early for that later harness. So close! |
Superhawk996 |
Aug 17 2019, 02:09 PM
914 Guru Group: Members Posts: 5,904 Joined: 25-August 18 From: Woods of N. Idaho Member No.: 22,428 Region Association: Galt's Gulch |
Mmmm those wire hubcaps! haha I always get a kick out of people that wanted to give their German cars more of a British flair. PO of my car stripped basked weave from dash and added wood veneer and also added other wood accents in center seat cache, center console, etc. In all honesty, I had a set of Enkei wheels on my 914 in the late 80's with fake center wheel knocks (IMG:style_emoticons/default/sad.gif) What was I thinking! |
JeffBowlsby |
Aug 17 2019, 02:33 PM
If it was built in June of 72, it should be a late 72 car. The last 5 of the VIN...is it 20827? That would be one of the last 72smade.
mankowski |
Aug 17 2019, 05:11 PM
Yes, the VIN is 4722920827. I misread the VIN tables on my phone while at the yard; back home now and can see them better -- indeed, it is a late 72. There are some hacks to wiring visible under the dash -- I'm not highly knowledgable about the routing of the main harness in order to assess its condition -- but PM me Jeff if you would like it and I can go back and pull.
Original color is yellow (L13M), and was repainted this shade of blue. Unusual bits on the car: the Amco vinyl shift knob (label is in bad condition) and Amco luggage rack (one mount missing). I pulled the fuel pump and MPS for spares, and the relay board that will allow for some practice of my planned work to repair the swage connection on my board at the 25amp fuse terminals. |
Lo-Fi Version | Time is now: 10th June 2024 - 05:32 PM |
