Kennedy Engineering Clutch Conversion Kit, Torque Specs? |
defianty |
Aug 18 2019, 09:41 AM
Senior Member Group: Members Posts: 659 Joined: 9-August 06 From: Essex, UK Member No.: 6,621 Region Association: None |
Finally getting close to installing the engine and today I wanted to get the gearbox on. When installing my Kennedy Engineering Clutch Conversion Kit I realised I've no idea of the torque specs?
Does anyone have a clue? Would a dab of (IMG:http://www.914world.com/bbs2/uploads_offsite/i.postimg.cc-6621-1566142916.1.jpg) Thanks. |
Mark Henry |
Aug 18 2019, 09:57 AM
Stock spec, 17-18 pounds. even cross pattern, 1/2 turn at a time.
Before it starts clamping on the disc I do a slight side pressure circle motion with the centering tool, then center it in relation of the fingers. No loctite, I've never seen an issue, it's not really the bolts holding it on, it's the clamping force. |
mepstein |
Aug 18 2019, 09:58 AM
914-6 GT in waiting Group: Members Posts: 19,315 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
This is from kep for the 3.2
@defianty Attached thumbnail(s) |
defianty |
Aug 18 2019, 10:15 AM
Stock spec, 17-18 pounds. even cross pattern, 1/2 turn at a time. Before it starts clamping on the disc I do a slight side pressure circle motion with the centering tool, then center it in relation of the fingers. No loctite, I've never seen an issue, it's not really the bolts holding it on, it's the clamping force. Thanks Mark, That's what I've done them too. In fact possibly a touch more as my torque wrenches lowest setting is 20 pounds. That's interesting I hadn't seen that before. I did wonder if it should be tighter as the pressure plate bolts go through the starter ring into the flywheel. 18 pounds didn't seem enough. |
76-914 |
Aug 19 2019, 08:47 AM
Repeat Offender & Resident Subaru Antagonist Group: Members Posts: 13,509 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California |
If those are the stock bolts Mark is correct. It doesn't take much to shear them. Ask me how I know! (IMG:style_emoticons/default/headbang.gif)
mepstein |
Aug 19 2019, 09:05 AM
I think mine came with bolts or I purchased separately. Too long ago to remember.
Mark Henry |
Aug 19 2019, 10:59 AM
I can't remember, even though I made my own conversion clutch, but are the 9 bolt flys 10mm? If so and the bolts are 10mm then my spec was wrong and 30lbs (KEP instal instructions) sounds reasonable.
My shop built 3.0 conversion ring and clutch: (IMG:http://www.914world.com/bbs2/uploads/post-26-1391891200.jpg) (IMG:http://www.914world.com/bbs2/uploads/post-26-1391891641.jpg) |
defianty |
Aug 19 2019, 11:18 AM
I can't remember, even though I made my own conversion clutch, but are the 9 bolt flys 10mm? If so and the bolts are 10mm then my spec was wrong and 30lbs (KEP instal instructions) sounds reasonable. My shop built 3.0 conversion ring and clutch: Just to make to clear Mark I'm talking about the bolts that go through the pressure plate and ring into the flywheel and not the actual nine flywheel bolts. |
Mark Henry |
Aug 19 2019, 11:29 AM
I likely built my adaptor ring different from KEP.
My ring is only held in with 3 countersunk short bolts, then the 6 longer pressure plate bolts go right through the adaptor and bolt to the flywheel. I also machined in the 3 dowel pins. I used an old VW bug flywheel to make the ring. Real hard steel I had to use carbide. (IMG:http://www.914world.com/bbs2/uploads/post-26-1391891615_thumb.jpg) (IMG:http://www.914world.com/bbs2/uploads/post-26-1391891160.jpg) |
Andyrew |
Aug 19 2019, 08:26 PM
Stock spec, 17-18 pounds. even cross pattern, 1/2 turn at a time. Before it starts clamping on the disc I do a slight side pressure circle motion with the centering tool, then center it in relation of the fingers. No loctite, I've never seen an issue, it's not really the bolts holding it on, it's the clamping force. ^this is my procedure for just about every clutch I've ever done. |
Lo-Fi Version | Time is now: 9th June 2024 - 09:56 PM |
