How to remove & replace Karmann plate on door jamb, Who's had experience? |
nihil44 |
Aug 21 2019, 12:39 AM
Member Group: Members Posts: 157 Joined: 28-January 12 From: Brisbane, Australia Member No.: 14,058 Region Association: None |
The wet soda blaster took to the door plate despite my efforts to mask it off and requesting him to avoid the area.
I see 914rubber sells a replacement kit of plate and pins. As I understand it, the pins are a type of spiral nail. What is the recognised for removal of these and also re installation? Thanks in advance <a href="https://s1258.photobucket.com/user/nihil44/media/IMGP3172_zpskajmxihe.jpg.html" target="_blank"><img src="https://i1258.photobucket.com/albums/ii532/nihil44/IMGP3172_zpskajmxihe.jpg" border="0" alt=" photo IMGP3172_zpskajmxihe.jpg"/></a> |
nihil44 |
Aug 21 2019, 12:56 AM
Sorry. Messed up the transfer from Photobucket. Hope this works
(IMG:http://www.914world.com/bbs2/uploads_offsite/i1258.photobucket.com-14058-1566370609.1.jpg) |
defianty |
Aug 21 2019, 01:34 AM
Senior Member Group: Members Posts: 659 Joined: 9-August 06 From: Essex, UK Member No.: 6,621 Region Association: None |
I managed to push the pins out from the access hole behind the speaker with a flatted screwdriver. Once I'd pushed them out a little I then pulled them out with a pair of pliers.
Specracer |
Aug 21 2019, 03:49 AM
Member Group: Members Posts: 100 Joined: 27-March 17 From: SE Mass Member No.: 20,970 Region Association: None |
+1, I used a small screwdriver to get it started, plastic body tools to edge each "nail" out further, pliers to finish it if needed. I was able to reuse the fasteners
defianty |
Aug 21 2019, 04:14 AM
rgalla9146 |
Aug 21 2019, 05:52 AM
Advanced Member Group: Members Posts: 4,563 Joined: 23-November 05 From: Paramus NJ Member No.: 5,176 Region Association: None |
Push or lever the pins out from the back.
Use a razor to lift the plate. Don't use a plier on the pins. Re-use the pins Attached image(s) |
dr914@autoatlanta.com |
Aug 21 2019, 07:54 AM
914 Guru Group: Members Posts: 7,887 Joined: 3-January 07 From: atlanta georgia Member No.: 7,418 Region Association: None |
we have the new pins and the badges if you cannot reuse yours, we use a small hammer and dolly to flare the new pins
iankarr |
Aug 21 2019, 09:40 AM
The wrencher formerly known as Cuddy_K Group: Members Posts: 2,480 Joined: 22-May 15 From: Heber City, UT Member No.: 18,749 Region Association: Intermountain Region |
Push or lever the pins out from the back. Use a razor to lift the plate. Don't use a plier on the pins. Re-use the pins Palma green metallic is a great color... (IMG:style_emoticons/default/wink.gif) |
rgalla9146 |
Aug 21 2019, 12:38 PM
Push or lever the pins out from the back. Use a razor to lift the plate. Don't use a plier on the pins. Re-use the pins Palma green metallic is a great color... (IMG:style_emoticons/default/wink.gif) Light Ivory is a far greater more period correct color. (IMG:style_emoticons/default/beerchug.gif) I should get a Karmann tag and stamp it to indicate the current fabulous shade. Hey Ian.... looks like rain for tonight. |
nihil44 |
Aug 21 2019, 01:48 PM
Thanks for all the replies.
Your help is much appreciated David |
Specracer |
Aug 21 2019, 02:14 PM
914werke |
Aug 21 2019, 05:23 PM
"I got blisters on me fingers" Group: Members Posts: 10,119 Joined: 22-March 03 From: USofA Member No.: 453 Region Association: Pacific Northwest |
The fastener is actually a screw so a twisting force will help when installing or removing
Lo-Fi Version | Time is now: 1st June 2024 - 05:43 PM |
