Fuel injector leaking question |
steuspeed |
Aug 23 2019, 06:35 PM
Senior Member Group: Members Posts: 1,008 Joined: 12-July 11 From: Portland, Oregon Member No.: 13,308 Region Association: Pacific Northwest |
Fired up the car and one of my injectors is leaking pretty good. Looks like its between the green plastic and the barrel. I'm guessing this is not repairable? The gas smell has been getting progressivly worse, but small enough to evaporate until now.
Rand |
Aug 23 2019, 06:42 PM
Sounds like it needs new seals. Easy.
Wait, how do you see, what you described? |
steuspeed |
Aug 23 2019, 06:50 PM
Sounds like it needs new seals. Easy. Wait, how do you see, what you described? I removed both injectors and re-plumed the hoses so I could look at them out of the engine. I turn the key to run the fuel pump and I can see the gas coming out between the plastic and the barrel. The seals look okay, but not brand new. |
Rand |
Aug 23 2019, 07:14 PM
Sounds like it needs new seals. Easy. Wait, how do you see, what you described? I renoved both injectors and re-plumed the hoses so I could look at them out of the engine. I turn the key to run the fuel pump and I can see the gas coming out between the plastic and the barrel. The seals look okay, but not brand new. There are two seals on each injector. Please replace them all while you are doing this. It may just fix everything. |
Rand |
Aug 23 2019, 07:20 PM
The leaking between the plastic and the barrel. I'll leave that to the experts. There are some good places to get injectors rebuilt.
steuspeed |
Aug 23 2019, 07:22 PM
The leak is outside the outter seal.
Rand |
Aug 24 2019, 09:52 AM
Superhawk996 |
Aug 24 2019, 10:11 AM
914 Guru Group: Members Posts: 5,899 Joined: 25-August 18 From: Woods of N. Idaho Member No.: 22,428 Region Association: Galt's Gulch |
If you can see the leak outside the outer seal, make sure it's not the fuel hose leaking.
If it is indeed leaking between the metal injector body and the plastic top with the electrical connection, you're screwed and need a new injector. Plenty of folks have extras for about $55 each rebuilt. |
dr914@autoatlanta.com |
Aug 24 2019, 10:28 AM
914 Guru Group: Members Posts: 7,896 Joined: 3-January 07 From: atlanta georgia Member No.: 7,418 Region Association: None |
will have to be rebuilt. We send to fuel injection corp and have them all rebuilt
Fired up the car and one of my injectors is leaking pretty good. Looks like its between the green plastic and the barrel. I'm guessing this is not repairable? The gas smell has been getting progressivly worse, but small enough to evaporate until now. |
Lo-Fi Version | Time is now: 9th June 2024 - 06:15 AM |
