| HansJan |
Aug 31 2019, 11:58 AM
Member ![]() ![]() Group: Members Posts: 403 Joined: 5-April 16 From: Sugar Land TX Member No.: 19,860 Region Association: Southwest Region
Hello,
It's time I start installing the 914Rubber fender liners. They come without paper or on-line instructions. The four pictures on the "old" 914Rubber website do not help me a lot. Anyone here has done this? Any tips? Br, Hans Jan |
| Garland |
Aug 31 2019, 12:37 PM
Restoration Fanatic ![]() ![]() ![]() Group: Members Posts: 1,428 Joined: 8-January 04 From: ......Michigan...... Member No.: 1,535 Region Association: Upper MidWest
| Mikey914 |
Aug 31 2019, 07:30 PM
The rubber man ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 12,772 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None
The old site still exists.
I’ll see if Matt can help post up on this too. |
| HansJan |
Aug 31 2019, 07:37 PM
Thank you. That’s very useful. |
| HansJan |
Aug 31 2019, 07:38 PM
| RickS |
Aug 31 2019, 08:07 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,408 Joined: 17-April 06 From: 'False City', WA Member No.: 5,880 Region Association: None |
The metal mounting clips that came with the kit rusted very significantly in one year. I replaced them with aluminum made out of flat-bar bent and drilled to match the originals. Before going to the work of mounting, you may want to contact 914 Rubber to see if you received stainless.
Part of my frustration was that you get 4 pieces of plastic liner with zero indication of which one goes where. That means since each plastic piece has two sides you have 7 opportunities to get wrong. Then multiply by the 3 other pieces and it can be hours of mix and match. A simple sticker on each piece (driver side front, this side faces tire. etc) would have solved all the trial and error. My advice is be super patient because when you get it right, they fit like a glove. That said, my Cayenne has factory fender liners which fit even better and they still accumulate an amazing amount of packed dirt in the rear of the wheel wells, so liners are not an install and forget about it. You may not have to clean as often though. |
| Mikey914 |
Sep 1 2019, 09:00 AM
PM me your address unless you bought in the last 8 months aid bet you can use these.
| Mikey914 |
| FlacaProductions |
Sep 1 2019, 09:08 AM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,169 Joined: 24-November 17 From: LA Member No.: 21,628 Region Association: Southern California
I found them on the new site by searching for "liner"
https://900designs-container.zoeysite.com/f...iner-set-of-4-1 |
Lo-Fi Version | Time is now: 14th March 2026 - 03:20 AM |
