bobboinski |
Member ![]() ![]() Group: Members Posts: 200 Joined: 23-April 16 From: Petaluma Member No.: 19,929 Region Association: Northern California ![]() ![]() |
I am looking for the gasket that goes between the alternator and the alternator tin/snorkel on a 1974 2.0. Got the part number from the local Porsche dealer but NLA.
It is a VW number 022903203. Searched but no luck. Hopefully I just did a crummy search. Any help greatly appreciated. (IMG:style_emoticons/default/beerchug.gif) |
IronHillRestorations |
I. I. R. C. ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 6,835 Joined: 18-March 03 From: West TN Member No.: 439 Region Association: None ![]() ![]() |
I just got some thick gasket material and cut my own. I also glue a piece of the gasket paper to the rear metal cover plate where the positive terminal connects, just for little extra insulation
jcd914 |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,096 Joined: 7-February 08 From: Sacramento, CA Member No.: 8,684 Region Association: Northern California ![]() |
I would check if 914rubber.com has them.
Jim |
bbrock |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,269 Joined: 17-February 17 From: Montana Member No.: 20,845 Region Association: Rocky Mountains ![]() ![]() |
I just got some thick gasket material and cut my own. I also glue a piece of the gasket paper to the rear metal cover plate where the positive terminal connects, just for little extra insulation +1 I did the same. Somebody on the Samba posted a template you could print but I couldn't get it to scale right so just used the cover plate and a compass to mark the gasket material. |
sixnotfour |
914 Wizard ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 10,912 Joined: 12-September 04 From: Life Elevated..planet UT. Member No.: 2,744 Region Association: Rocky Mountains ![]() ![]() ![]() |
from samba
template for alternator gasket 021903637 / 021 903 637 Print out at 300dpi and you're good to go. Attached image(s) ![]() |
sixnotfour |
Attached thumbnail(s) ![]() Attached image(s) ![]() |
bbrock |
from samba template for alternator gasket 021903637 / 021 903 637 Print out at 300dpi and you're good to go. That's the one I tried but never could get it to print right on a Windows machine. Spent more time fiddle farting with it than it took to just use the cover as a template. Maybe it works better on a Mac? (IMG:style_emoticons/default/confused24.gif) |
bobboinski |
Thanks for the replies! I think I will try to make the gasket. Don't want to wait for shipping from Australia but at least someone makes it. Didn't show up in my searches. Thanks again for all the help, this is a great place. (IMG:style_emoticons/default/beerchug.gif)
Spoke |
Jerry ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,194 Joined: 29-October 04 From: Allentown, PA Member No.: 3,031 Region Association: None ![]() ![]() |
Here's a simple gasket template I made with Powerpoint. The Powerpoint file is below. It has 2 concentric circles with 3 through bolt holes placed 120 degree apart from each other. I printed this then with a razor knife outlined the shape on a piece of gasket material and cut it out with scissors.
Attached image(s) ![]() Attached File(s) ![]() |
porschetub |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 4,887 Joined: 25-July 15 From: New Zealand Member No.: 18,995 Region Association: None ![]() |
Use some JB weld black silicone ,IMO its not a place for a paper gasket the original I always find not seating properly anyway.
bobboinski |
bobboinski |
Here's a simple gasket template I made with Powerpoint. The Powerpoint file is below. It has 2 concentric circles with 3 through bolt holes placed 120 degree apart from each other. I printed this then with a razor knife outlined the shape on a piece of gasket material and cut it out with scissors. Thanks for the link. I'm going to be working on the engine tomorrow, hopefully I get to this point in reassembly. There appears to be quite a difference in the Malcolm engineering gasket and the templates. |
porschetub |
Lo-Fi Version | Time is now: 19th July 2025 - 03:27 AM |
