> Ball Joint Removal, Is there a special tool?
BENBRO02
post Sep 8 2019, 02:54 PM
My ball joints are very stubborn. I tried a pipe wrench and they don't budge. Is there a specific tool that goes in the slots on the bottom ring to make removal easier? I haven't given up on the idea of driving to Okteenerfest yet.
Replies(1 - 9)
jcd914
post Sep 8 2019, 03:01 PM
QUOTE(BENBRO02 @ Sep 8 2019, 01:54 PM) *
Yes there is a special socket for those nuts.
It fits into the four slots, some versions have a ring that seats outside the nut to keep the socket on the nut as you loosen or tighten.
I think there was a member or vendor that was making and selling the socket.
Jim
ClayPerrine
post Sep 8 2019, 04:24 PM
Big hammer and a punch.
BENBRO02
post Sep 8 2019, 05:24 PM
QUOTE(jcd914 @ Sep 8 2019, 05:01 PM) *
Jim
thanks Jim
jim_hoyland
post Sep 8 2019, 06:01 PM
Get that VIN ?
Like this ?
rhodyguy
post Sep 8 2019, 06:22 PM
Copious amounts of Aerokroil, tap on the outside with a hammer, spray and tap repeatedly, wait 24 hours and use an air chisel with a V shaped tip on one of the tangs. Scars the tang a bit but no big deal. Worked fast for me. Beating on it with a cold chisel and BFH? Nope. When one of those sockets lets go using a breaker bar or pipe wrench with a cheater it can be painful and bloody. Push away not towards the control arm. Don't push or pull your car off the jack stands.
post Sep 8 2019, 06:40 PM
914-6 GT in waiting
If you could get a pipe wrench on it, it will make easy work of it.
BK911
post Sep 9 2019, 08:53 AM
I use the special socket on an impact, and use a jack to hold the impact tight to the nut. Zap a few times, heat and penetrate fluid, lather rinse repeat until the nut spins off.
post Sep 9 2019, 09:19 AM
914-6 GT in waiting
Sorry, re-read the first post. Heat the nut with MAP gas, spray some penetrating oil or touch some paraffin to the joint while hot then pipe wrench. Heat will expand the nut and break the corrosive bond.
If you have a he socket and impact gun, go for it after you heat the nut.
Chi-town
post Sep 9 2019, 11:45 AM
Get the socket and a really mean 1/2" impact, put the arm on the floor, push the gun into the nut with your body weight, pull the trigger..
- Lo-Fi Version Time is now: 31st July 2025 - 05:43 PM
