Early Window Scraper, How to reinstall them |
Howie's 914 |
Sep 23 2019, 11:01 AM
Member Group: Members Posts: 76 Joined: 29-June 04 From: Greensboro, NC Member No.: 2,273 |
Ok, so I am finally back around to working on the car. I took it apart long ago before paint and body. So now I have all new rubber and fuzzy and Alum strip from 914Rubber. But, How do I put the window scraper on the alum strip. Any pic's would be great. I have searched everywhere but can't find anything.
Thank you |
SirAndy |
Sep 23 2019, 12:03 PM
Resident German Group: Admin Posts: 41,676 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
The felt strip part?
Last time i did this i put the bottom side into the channel and then used a blunt flat screwdriver (a sharp one will pierce the felt strip) and pressed the top edge of the strip into the channel. (IMG:style_emoticons/default/popcorn[1].gif) |
Howie's 914 |
Sep 23 2019, 02:52 PM
No not the fuzzy, It's the top rubber strip that on top of the door to the window.
SirAndy |
Sep 23 2019, 02:57 PM
No not the fuzzy, It's the top rubber strip that on top of the door to the window. Ah yes, if i remember right, i did the same thing after trying for hours to slide it in with lots of lube. Put one side in the channel and use a blunt object to squeeze the rubber in. It's been 15 years though and my memory is a bit fuzzy on the subject ... (IMG:style_emoticons/default/unsure.gif) |
rhodyguy |
Sep 23 2019, 03:05 PM
Chimp Sanctuary NW. Check it out. Group: Members Posts: 22,090 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch |
The RUBBER scraper slides in to the channel on top of the door from the rear. LOTS of glycerin on the seal and channel. Go slow in small increments. Pushing and guiding at the same time helps. The seal stretches. Don't trim it for length for a couple of days.
The outer fuzzy is held on by some screws. You have to remove the glass to access them. Usually hard rusted. Inner fuzzy is a press on. You might consider appropriate new rear end caps. |
Mikey914 |
Sep 23 2019, 03:51 PM
The rubber man Group: Members Posts: 12,678 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None |
A techniqe that will work is to push down on the end and pull on the seal. This stretches it to the point it will pop in. Then wall it in using the technique.
The early door end cap will also have a channel that it needs to slide into. Compress it well before cutting. You can also installwith late door end cap too. They look sharp. Attached image(s) |
rgalla9146 |
Advanced Member Group: Members Posts: 4,569 Joined: 23-November 05 From: Paramus NJ Member No.: 5,176 Region Association: None |
Put the flange in the vise ...slowly push and pull with lube.
Lo-Fi Version | Time is now: 8th June 2024 - 06:43 AM |
